Question about Pentax MZ-50 35mm SLR Camera
Can anyone help me with this one?
I just got a second hand mz 50 and the shutter wasn't sitting right, I assume that's an easy fix. My main problem however is that I bought 2 CR2's, turned it on once and now the lcd says they're flat. I'm after reasons why it might show they're flat. Didn't leave it on and didn't put them in backwards. Any answers are appreciated.
2 Suggested Answers
  • 185 Answers
SOURCE: shutter
kirstyanne00,
open the film door and check the shutter blades. did you accidentally push the blades in when loading the film? if so take the camera to a camera repair shop, the technician may be able to reset the blades while you wait.
or send it to pentax repair center for an estimate cost to repair.
Posted on Dec 11, 2008
Pictures are blurry
The most common causes of blurry pictures are not holding the camera still and correctly pressing the shutter release button or using a slow shutter speed.
Let\'s talk about properly holding your camera first. Always hold your camera with both hands. With an SLR such as yours, grip the left side of the camera with your left hand and cradle the camera from underneath with your right hand using you thumb and index fingers to zoom. Hold your arms so that both elbows rest on either side of your chest and brace the top of the camera against your forehead. This forms a rigid triangle of support.
The second thing you must do is properly press the shutter release button. Do not poke the button because you will jerk the camera and that can cause blur. Instead, start to press the button gradually increasing the pressure until the shutter trips. It should trip almost by surprise. This is very similar to how a marksman pulls the trigger on a gun.
Assuming that you are holding your camera correctly, not "punching" your shutter button and your camera is not defective, here are two easy ways to solve your problem. First, you could use the manual exposure mode and keep your shutter speed at 1/500 second or faster. Second, go to the "S" shutter priority mode and set the shutter speed above 1/500 second. Your camera will automatically adjust the f-stop (lens diaphragm opening) and "film speed" for proper exposure. Please let me know if this resolved your problem.
Aug 02, 2014 | Nikon D3100 Digital Camera
When we take picture it show picture blurry
Aug 02, 2014 | Nikon D3000 Digital Camera
Remove starter
I personally have never seen a starter on any vehicle
in 50 years, that wasn't at the back of the motor,on either
side
Common sense here, as it has to turn the flywheel on the
back of motor next to transmission bell housing
In a few very rare cases,not yours, they have been on
top over the motor in some strange location
When anyone asks that question, I assume you never
opened the hood or went under the vehicle & would only
ask if you intended to remove the starter yourself & never
worked on a car before !
Nov 15, 2012 | 2010 Dodge Journey SE
I just had my fuel pump replaced. Now my check engine light is on and it gives an error code for fuel rail pressure.
Go to Autozone/Advanced Auto have them read the code and erase if possible, and see if it reappears.... 50% of the time it will never reappear.
If they cant erase it, read up in your OM where it talks about troubleshooting and it should have the reset memory instructions listed. If not, call the dealer and ask them. Usually you have to turn you key to accessory for x seconds, back to off for x seconds and it will reset. You can always disconnect battery for 24 hours and the computer will reset automatically.
Sep 19, 2011 | 2005 Lincoln Navigator
The shutter's spring collapsed and now you need to force the shutter open.. Is that easy to fix? If yes, how much would that cost me?
Best thing to do is to go to the shop and ask. It shoudn't be too expensive, because it's pretty easy to fix with the right tools.
Dec 30, 2009 | Pentax MZ-50 35mm SLR Camera
PENTAX mz 50 I WAS TAKING A PICTURE WITHOUIT ROLL
Just a guess, but it sounds like the shutter is stuck in the closed position. Maybe you can have the camera serviced. Try to find an online film enthusiast club, such as on Facebook and elsewhere. They might be able to direct you to where you can have your camera serviced. I can tell you that the cost of that camera is about $100 used, and repair might be the same price, so it might be better to buy another one off eBay. They have MZ-50 models for sale and lots of others. Film gear is cheap these days, but repair is not cheap. Better to buy another camera. I'm sorry about your problem and hope you can resolve it. If this was 10 years ago, you'd have a warranty and could have it fixed, but these days it's just easier to buy another camera and probably the same price or cheaper to buy another used/second-hand camera than to pay for repair. Good luck to you.
Apr 06, 2009 | Pentax MZ-50 35mm SLR Camera
Shutter
kirstyanne00,
Oct 25, 2008 | Pentax MZ-50 35mm SLR Camera
Shutter problems
sean baker,
If the camera was working when you stored it and the shutter fires occasionally, it's probably battery corrosion. Clean the contacts with a pencil eraser,or contact cleaner tool.
What kind of camera ?
Sep 09, 2008 | Pentax MZ-50 35mm SLR Camera
Broken shutter
The C-50 camera is notorious for the broken door and/or broken track. It was fixed on the C-60 model.
There are a few shops on eBay that sell the front door, its a very easy replacement, just two screws and a guide plate on the bottom that you install and assuming your track is still operational, you'll beable to use your camera.
Nov 16, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Apr 25, 2007 | Pentax MZ-50 35mm SLR Camera
Pentax MZ-50 35mm SLR Camera Logo
401 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
