Question about Dehumidifiers
My challenge dehumidifier has stopped collecting water. Think it needs regasing. Where will I get the gas or is it not worth fixing.
    Problem Solver:
  • 12 Answers
There is often an eliectrical problem, such as perhaps the wate collection bucket doen't connect with the dehumidifier?
You could try taking it in and pulling it out while pressing buttons or turning the knobs and if your lucky you might trigger it to work..
Posted on Feb 10, 2012
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
  • 1632 Answers
SOURCE: motor runs on dehumidifier but doesn't collect water
If it doesn't get cold change the temperature,
Put the float wire up.
finally it is out of r-14- freon.
Vitally
Posted on Jun 02, 2009
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
SOURCE: My dehumidifier does not collect any water.
One of two things is happening here.
1. Either the compressor isn't running or...
2. The water is not being routed to the collection bucket properly. This dehumidifier has an option to connect to a hose that can be routed to a drain. Look in the back of the unit to see if you see a connection that could accomidate a garden hose. If you see this and there is no hose connected you may be dumping the water on the floor instead of the bucket. This could explain why your carpets are damp.
Posted on Jun 22, 2009
  • 80 Answers
SOURCE: kenmore dehumidifier does not collect water and I
Check to see if the compressor and fan are running. If this is true, additional diagnosis will have to be done by a technician. Usually the cost of repair for this type is far more than replacing it.
Posted on Oct 03, 2009
Have a dehumidifier, Delonghi DE500P. Unit operates but no water collecting in bucket.Level set to 35%. Can freon be added to recharge?
the short answer is yes , but id caution you on the need too first?
first check the basics:
bucket full lite not on (blinking)
filters clean ?
both fan and compressor inside running (sometimes the fan runs but the compressor does not?) listen carefull for them both?
if your unit needs recharged odds are it's not financial feasible to do so , first you have to fix cause of gas leaking out ? what ever that is ? then you need to add service ports and finally you need a gas charge , this would or could cost hundreds of dollars , a entire new unit is less 200 bucks unless you do all this work your self , but id tend to think if you had all the tools and knowledge to do that youd not of asked here in the first place
Jul 21, 2015 | Dehumidifiers
My dehumidifier is collecting water but its not going i ,its going all over my floor?
Go for the simple fix first. Unplug unit and look inside once the cover is removed. It may be that dust and lint that collects on the coils have dropped down into the pan / tray and have blocked the little hole that would allow the water to go into the bucket. Only try this if you can safely remove and replace the cover.
Oct 20, 2014 | Dehumidifiers
The dehumidifier stopped collecting water. It was working great, then just stopped collecting water one night.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 17, 2011 | Bionaire Dehumidifiers
I have an ad50 dsr1 whirlpool dehumifier. Has been great for a couple years but now when turned on it instantly trips GFI. After further investigation I found the wires on top of the compressor are...
heatman101
Jun 02, 2011 | Whirlpool AD50DSL Dehumidifier
My Maytag dehumidifier runs but does not collect water in the tray. Instead, it appears to leak from the bottom and ice formed near one of the side portions. Please let me know what you think is the...
This one has a leak in the refrigerant system... it will need to be found, fixed, and recharged...which will cost more then a new one...in most cases.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
May 13, 2011 | Maytag Dehumidifiers
Our dehumidifier is no longer pulling moisture out of the air. I took the back off and the fan is still running. So motor or condenser? And is it worth fixing? The machine is approximately 6 years old.
heatman101
Nov 28, 2010 | Kenmore 54501 Dehumidifier
Our Challenge 4151319 Dehumidifier has ceased to collect water. The fan operates perfectly. Can I get it serviced in Devon?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Good luck
Aug 19, 2010 | Maytag M7DH65B2A Dehumidifier
A challenge dehumidifier not collecting water
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 03, 2010 | Maytag M7DH65B2A Dehumidifier
Runs all the time, not collecting water
I don't know your particular unit, but my guess is that the compressor is bad. If it is old, it may not be worth fixing.
Sep 19, 2006 | Goldstar DH504EL Dehumidifier
Dehumidifiers Logo
217 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
