Question about Electrolux Heating & Cooling
Kelvinator fault code e6
Split system A/C fan works but no cooling, showing error code E6.
hvac1960
  • 2133 Answers
SOURCE: First time I've tried using the cooling on my
E-1 error means coil sensor (cooling) defective. Replace it.
Posted on Dec 06, 2010
Testimonial: "Thanks heaps. I'll get back to the retailer for parts under warranty. Too far out of town for labour warranty but knowing the problem helps. thanks"
hvac1960
  • 2133 Answers
SOURCE: Error code E6 Pioneer Split
E-6 Outlet pipe sensor open/short circuit. Replace it.
Posted on Jan 01, 2011
  • 11800 Answers
SOURCE: I have a Fisher's split
Fisher is a no-name brand that is manufactured in China by an company that manufactures parts for a lot of other brands, most notable Toshiba and Daikin.
In your case both errors are caused by a faulty pressure switch:
- E3 Outdoor Activation of high pressure switch
- E6 Outdoor Compressor start up error
What that means: something is blocking the flow of the coolant fluid, either a reversing valve that no longer operates correctly (is stuck not fully opened) or there is dirt in the lines; when the compressor starts the pressure it's forced to produce is larger than the rated one so the error code is triggered. If the pressure is larger than the maximum rated one the pressure switch will prevent the compressor from running and the second error code will be triggered. When you press the reset button the error is wiped and the compressor can start again. All of this has absolutely nothing to do with the temperature sensors, both in and out.
To fix that the circuit will have to be opened and the reversing valve and the pressure sensor tested - because this implies emptying the freon circuit it's a job that only a certified repairman can do, you will have to call one.
Posted on Aug 08, 2011
koolbreezes
  • 540 Answers
SOURCE: KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Posted on Aug 23, 2008
  • 121 Answers
SOURCE: kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Posted on Oct 16, 2008
Split a/c system frigidaire model ffms221wq20 Code E6
Code 'E6' does not show up. Here is the Sears website with codes. It also shows problems and fixes which may help you narrow down your problem.
Model FFMS221WQ20 FRIGIDAIRE SPLIT ROOM AIR CONDITIONER Parts
Sep 18, 2017 | Frigidaire Heating & Cooling
Voltas verticool showing e6 unit not working !! What happend?
From search I found that on a Mitsubishi it said e6 and e7 that is an indoor/outdoor communication error. I had that happen once when I installed one of these split units, got e6 and realized I forgot to connect the wire on the indoor part, that triggers the outside to go on when thermostat inside starts the cooling cycle. Maybe a wire pulled loose. There was terminal blocks on each unit on one I hooked up, check breakers too.
May 03, 2016 | Heating & Cooling
What is error e6
e6 error air conditioner Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your e6 error air conditioner question. Get free help, tips & support from top experts on e6 error air conditioner related issues.
air conditioner e6 code Questions & Answers - Fixya
...one inverter 12k I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication ...
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 1 of 3 for Mitsubishi Electric .... Ductless Air Conditioner ...
Jan 23, 2016 | Heating & Cooling
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
Heating & Cooling Logo
2,316 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
