Question about Lexmark Office Equipment & Supplies
Hi My Mexmark X73 printer-scanner does not print nor it scans.
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug the power cord for 30 minutes . This resets your printer . Plug back the power cord to printer .
This will clear most of the problems .
If this does not work uninstall the driver file from the printer and reinstall the driver file .
Thanks for using Fixya
SAM ANDERSON
Posted on Oct 23, 2008
Will the printer scan or copy if the ink is dry?
The printer will san to screen but not to a copy. No ink, no copy
Feb 11, 2011 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 Printing Problem
When you say that your all-in-one system will copy, but will not print from the computer, this tells me that there could be a connection problem between the printer and the computer. This is more then likely a driver problem. you will need to go to lexmark and download the latest drivers for your operating system.
But this could also be a broken or loose cable.
Apr 15, 2010 | Lexmark X73 All-In-One InkJet Printer
My printer, X73, jams up the paper when I try to print, I don't see or detect anything foreign in the rollers
It tends to be the problem of roller . Roller is not moving smoothly , just manually move the roller to and froth and then close the lid properly . Now try to take print it will work fine .
Hope this helps .
Mar 24, 2010 | Lexmark X73 All-In-One InkJet Printer
Printer works, copier and scanner do not
you might try enabling bi-directional printer support in printer properties, if its paralell cable then it is in bios, epp or ecp.
Jul 27, 2009 | Lexmark X73 All-In-One InkJet Printer
I have a lexmark x73 i'been instaling so manytimes on order to make the scaner to work but nothing I would apreciatte if you can give me some tips or help thanks
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X73) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X73 All-In-One InkJet Printer
Vista
is there's nothing from lexmark, who makes the drivers, then there's nothing to it. you could set up a print server, and maybe that will do it.
Jun 21, 2008 | Lexmark X73 All-In-One InkJet Printer
Need driver for Lexmark X73 on Windows ME
click here
let me know if this is what you need if its not the right one then give me shout back and ill locate it for you ok
Apr 10, 2008 | Lexmark X73 All-In-One InkJet Printer
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanner will not scan
Set this options un der Control panel Scanner and camera. If fails try this, Uninstall everything HP Installed. Unplug the scanner. Then reboot. THen install the drivers and applications. Then reboot. then insert the HP scanner into the USB.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
My 4 in 1 wont scan but does print
Before we give up on the scanning/copying ability of your machine. Try unplugging the machine from the wall and from the computer for at least a couple minutes. If that doesn't work, You may also check for a factory reset switch or reset mode you can choose. http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:94:0:0&os_group=WinXP&searchLang=en Last but not least. Uninstall the printer again, unplug it from the wall and computer. Make sure you restart the machine and even shut it down before trying to reinstall the drivers. The above site has a patch for the scanner. Not sure if its what may be ailing yours. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Lexmark X73 All-In-One InkJet Printer
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
