Question about Dell for Optiplex GX620 CD-RW/DVD-ROM Combo Drive
Dell optillex comp not booting - Dell for Optiplex GX620 CD-RW/DVD-ROM Combo Drive
  • Dell Master
  • 27,725 Answers
Is this a problem with your cd-rw drive or your computer not booting??
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
hope this helps you
Posted on Feb 11, 2012
Inspiron zino HD won't boot up it just stays at the dell screen
Try booting into safe mode restart comp and its 1 of the f buttons f5 or something ea model number is different when in safe mode make sure you go to safe with networking and download new drivers of that doesn't work let me know ill walk u thru how to Chang the way you boot up your pc
Apr 03, 2013 | Computers & Internet
Unable to boot the windows xp cd
check your boot settings in the comp bios/cmos set-up, you should the boot order of the devices in your system, make cd/dvd romyour 1st boot device then make the hard drive your 2nd boot device then so on, save the changes you had made and reboot insert your windows installation disc then from there it will boot to the xp cd
Dec 07, 2009 | Dell Dimension 4600C PC Desktop
Booting comp
The default password for Dell computers is DELL.
Mar 17, 2009 | Dell OptiPlex GX270 PC Desktop
Please help going out my head with this problem
dell machines store information about the recovery partition in the boot record of the computer.
If your computer was reformatted earlier or the original boot record was replaced this would happen.
What you can do right now is insert the dell recovery cd in the drive and restart the computer. it will ask you on the screen to press any key to boot from cd press any key and the reinstallation formatting options would appear on the screen.
I hope this helped!
Regards
keshey
Feb 13, 2009 | Dell Microsoft Windows XP Home Edition
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Sony viao, comp. boots up. screen very dark.
Is the screen just dark s that you can barely see what's on it, or is it completely blacked out?
Jul 27, 2008 | Dell Latitude C610 Notebook
Factory restore
some dells are preconfigured with a restore partition. I wouldnt know if your unit still have this. but try this
Upon Boot up. (when you see the dell logo) Press Control F11 and see if it brings you up to a menu that would restore your laptop to factory configuration.
Follow the oncsreen instructions and you should be able to reinstall it automatically
Assuming you dont have the restore partition anymore then you need to to do it the conventional way and that means having all those recovery disc (hope you still have them). Insert the first disc and boot from there.
Apr 16, 2008 | Dell Inspiron E1505 Notebook
System won't boot
Better you try with a bootable CD, if that works then check for your Hard Disk it might got faulty or crashed.
Feb 04, 2008 | Dell Dimension 4600 PC Desktop
Trying to boot from a hd from my old comp
MS Windows XP when installed to an HD will "marry" itself to the hardware of the original computer specifically the motherboard. Transplanting the HD to another PC with a different motherboard will result in a cycling blue screen of death or protective message requiring that you reboot. Running in Safe Mode will not also be allowed.
You need to re-install your OS (boot from CD) but choose the 2nd repair option rather than a new/clean install or the first repair option if you want to preserve your other applications as well as your settings/configuration. Doing this will allow the OS to install the new device drivers and delete the old ones.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
God luck and kind regards.
Jan 13, 2008 | Computers & Internet
Dell  for Optiplex GX620 CD-RW/DVD-ROM Combo Drive Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
