Question about Linksys (WIFIDESKTOP) Wireless Adapter
Change the channel
I can't change the internet channel. I am on channel 6 but i' d like to change into 1 or 11 because the connection is slow or it lasts 2 minutes.
How can i solve this problem?
    Problem Solver:
  • 11 Answers
• access rtrs gateway, default is 192.168.1.1
• click on wireless tab
• wireless channel === dropw down arrow, select 11
• save settings
>>>> just make sure that while making this changes your laptop or dsktop is hardwired to any of the numbered ports of the router
Posted on Oct 24, 2008
Advent 9315 wifi
How are you connecting to the internet?
1. Wireless
2. Wired
This can have an effect on the speed. A wired connection is not subsceptable to any interference and wont slow down from it.
A wireless connection can be slow because of the router, other things that broadcast radio signals, other things that broadcast non radio signals (like flourescent lights.)
How are you testing the speed? Unless you go to a website that has a speed test program or you are running a speed test application, there is no way to know for certain that your speed is what you believe it is. Your speed can also change due to the amount of people on the internet and other things like equipment failure outside your house.
Mar 31, 2014 | Zyxel Computers & Internet
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
Bsnl internet is very slow in dlink dwm 156
So, If you have internet connection speed problem with your wireless try with the following steps,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.com before and after following these steps.
Apr 04, 2013 | Computers & Internet
I have followed the steps in your installation guide and all the lights in the router were already green but i still can't connect to the internet. I only use a notebook computer and it does not have a cd...
Step 1 : Connect Router - Notebook ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Feb 25, 2011 | Belkin N150 Enhanced Wireless Router...
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address 192.168.2.1
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address 192.168.2.1 in to 192.168.1.2
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Sep 06, 2010 | Belkin Surf Share Wireless USB Adapters...
I'm unable to connect to the internet using my linksys wireless-g pci adapter to a Netgear router. It lists the router in the wireless network range, but cannot connect to it. Suggestions?
Go into the network settings through the browser. Go the where you change the "Channel" the router is transmitting with and change that to channel 6, instead of automatic. If you can access to router but not the internet, go to internet options through the browser and go to the connection tab and uncheck the box that deals with proxy server. That box should be unchecked and the box for automatically detect settings should be checked.
Oct 01, 2009 | Linksys : Wireless-G PCI Adapter with...
Low connection speed
I understand that you are getting low wireless speed through the adapter. I would suggest you to upgrade the drivers for the adapter. If the issue persists, then please change the channel on the wireless router.
Hope this helps.
Regards
Anand
Jun 18, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
How do i change the "channel" of my wireless internet?
The belkin USB adaptor does not appear to have a channel selection option. Like most WiFi adaptors it scans and connects to the available networks assuming the security matches.
What you need to do is change the BROADCAST channel in your router or access point. If you are unsure how to do this I suggest you post the make/model and I'll try to assist you.
Ensure you use 1-11 as this adaptor does not support ch 12 or 13 wheras some routers do.
You may find the NETSTUMBLER prorgam useful in finding a free channel to use.
Jul 15, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Problem with Widows Vista and Internet Connection
In this case you have to get your router reset to default settings and then set it up once again and also setting upa new wireless network with a different channel because the issue you're facing is because of channel selection.
Apr 22, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys (WIFIDESKTOP) Wireless Adapter Logo
222 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
