Question about Samsung SMH7185STG Stainless Steel Microwave Oven
Display & lights go out after use when door is opened, can uplug unit, then plug back in and display & lights work again until next use
When unit is finished, the display and lights all go out like a power failure. You can unplug unit, the plug in again and all works until the next time it is used.
    Problem Solver:
  • 9 Answers
If it's doing that u may have a short in the cord somewhere I would try while plugged in next time u use it don't unplug it but next time it goes out move cord a little bit n see if it comes back on if so that's the problem r u getting bad connection somewhere try another outlet too
Posted on Feb 10, 2012
My microwave wont heat up but runs normal
The make & model number would be helpful. There are alot of veriables that might cause this to occur. How long was the MW in use (the unit might have been to hot and the safety engaged) keeping the fan on to cool it down. There could be an issue with with one of the door interlock switches. Depending on the engineering, the control board could have had a hickup via a over current & shut down to protect itself. During the cut out was the cavity light on when the door was open. was the display blank. If you unplugged the unit waited a minute & then plugged it back in, did it operate again. It is not a good idea to open the control panel up, if your do not understand how to do basic electrical troubleshooting.
Mar 27, 2012 | Frigidaire Microwave Ovens
GE SPACEMAKER XL1800 IS NOT HEATING FOOD - GIVING "SENSOR ERROR" ON DISPLAY. I am a handy guy capapble of fixing if you can help me out w/the part I need
hello,
if you have a sensor, it means, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
thanks.
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave stopped working and gave a sensor error message. Any ideas
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
  • The humidity sensor (gas sensor) has failed.
Maybe the controller is "scrambled" and a hard reset will fix it.
If that doesn't work, leave it unplugged for about 5 minutes.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
I replaced the light bulb, now it displays -F6- and pushing any button causes a humming noise.
I left the unit unplugged over night, plugged it back in the next day and still had the same problem.
Oct 13, 2008 | Roper Microwave Ovens
Hi. I pressed the 'quickstart' button on my micromat 900 w microwave and used it for 10 seconds. On pressing the 'door open' button, the display panel is showing '1' rather than the cooking time or the...
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Sep 28, 2008 | AEG Microwave Ovens
Microwave runs but does not heat food either with sensor or manual timing. Occasionall will displasy 'SENSOR ERROR'. Have closed door and pressed CLEAR/OFF per manual instructions, but still does not...
INFO: On GE models, "SENSOR ERROR" appears on the display when:
If the reset didn't fix it:
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Do you have the model number?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Sep 07, 2008 | GE Microwave Ovens
Numbers and light, but no power
It sounds like you have a bad control unit (the circuit board). We repair controllers nationwide for $39.995 in most cases, but if a part is needed which we cannot get, then it will need a new board. That can be ordered from http://www.vancebaldwin.com If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 06, 2007 | Sanyo EM-P672W Microwave Oven
Maytag Over the Range Microwave
Assuming the entire power line from the breaker to the microwave cord is okay, it's almost certainly a bad connection on the circuit board of the control panel assembly. For reference, we repair these from all over the country for $32.50 postpaid.
Oct 16, 2006 | Maytag MMV4205 Microwave Oven
Samsung SMH7185STG Stainless Steel Microwave Oven Logo
74 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
