Question about HP LaserJet 4050 Printer
What is 55.A Printer Error and what can I do to fix it
The printer sounds if its about to print but 55.A printer error comes up and tells me to press go to continue but this does not work.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Dear Client! Please match the size of paper with Tray size and then print it.
Posted on Mar 17, 2018
SOURCE: HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
please let me know what is rail and carriage bushings ?
Posted on Jul 09, 2008
SOURCE: printer will not start
This is likely a hardware problem. However you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord. If this this does not clear the error you probably have a hardware issue. On my printer, after going through a diagnostic procedure with the HP Chat Tech and concluding a hardware issue I did a bit more research and then took the printer apart. It turns out that a fairly common problem is for the large white gear on the left side of the printer that drives the ink pump comes off the shaft. I reassembled it to the shaft and put the printer back together. When I plugged in the power cord the printer started and did about a 5 minute maintenance procedure and now works fine.
Posted on Jan 29, 2009
SOURCE: HP Business Jet 2800 stall error message
See http://fixyourownprinter.com/forums/inkjet/42029
"Carriage Stall or Jam" by Stephen
Clean encoder strip with clean water, clean rod with denatured alchol you can get at Home Depot and lube with Synthetic Lubricant that you can purchase at a gun shop for about $4.
Posted on Apr 10, 2009
  • 169 Answers
SOURCE: HP C6180 - IMPROPER SHUTDOWN
Not a big problem,try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
SOURCE: Error 68.2 permanent storage write
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
here is the lin for additional solution:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Posted on Oct 26, 2009
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete · Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
55.00.00 error message display on the control panel
Error 55 is a major Engine or DC controller issue.
HP LaserJet Enterprise Printers 55 00 0x and 55 0x 06 Errors
Try spares from salvaged printers. Look for "working pull from damaged unit". Of course reconfirm model and spare compatibility.
Printer Works RM1 9371 000 DC Controller As M775 mfp
HP LaserJet DC Controller For M775 Printer RM1 8898 - USD70+shipping
Mar 18, 2016 | HP LaserJet M775DN Laser Multifunction...
I have a ml-2165w laser black printer, when try to print it tells me me disconnect and press on button, the light turns green then blicks then turns red. What do I do&gt;
Dear
There may be some error related to fuser or LSU.
Pl. down load samsung easy printer manager from samsung site or it can found on the disk provided.
run it it show the error detail.
Thanks
Oct 06, 2014 | Samsung ml-2165w - laser printer -...
HELP ! My HP C309a photosmart 3in 1 printer
Hello and Welcome!
The error
Oxc19a0040 is mostly occurred in HP printers
To solve the error code
Oxc19a0040,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
Thank you for using FixYa!
Jun 08, 2012 | HP Photosmart Premium C309A All-In-One...
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
    here are some error code list for you for your s300 printer.
    Got this from slayo.com
    hope this list will help you find answers to your questions. Goodluck!
    ERROR CODE LIST
    Error codes are displayed on the monitor of the host computer connected to the printer. For error
    code display, keep the status monitor open.
    Error Code
    Error Corrective Action
    1000 Paper out error Load paper, and press RESUME button.
    1200 Front cover open error Close front cover.
    1300 Paper jam error Remove jammed paper, and press RESUME button.
    1401 Head ID error Replace print head, as it has failed.
    1403 Head temperature sensor rank error Replace printer, as it has failed.
    1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
    1700 Waste ink near-full error Replace printer, as it has failed.
    5100 Carriage error Replace printer, as it has failed
    5200 Head temperature rise error Replace printer, as it has failed
    5400 Printer temperature rise error Replace printer, as it has failed
    5B00 Waste ink full error Replace printer, as it has failed
    5C00 Purging operation error Replace printer, as it has failed
    5800 EEPROM/NVRAM error Replace printer, as it has failed
    6810 EEPROM print head information error Replace printer, as it has failed
    Operator Call Error
    Orange lamp
    2 times Paper out error Load paper, and press RESUME button.
    3 times Paper jam error Remove jammed paper, and press RESUME button.
    6 times Print head not-installed error Install print head.
    7 times Print head error Replace print head, as it has failed.
    8 times Waste ink near-full error Replace printer, as it has failed.
    Service Call Error
    Toggle blinking
    2 times Carriage error Replace printer, as it has failed.
    4 times Purge error Replace printer, as it has failed.
    6 times Internal temperature rise error Replace printer, as it has failed.
    7 times Waste ink full error Replace printer, as it has failed.
    8 times Print head abnormal temperature rise error Replace printer, as it has failed.
    9 times EEPROM error Replace printer, as it has failed.
    10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
    Sep 11, 2009 | Office Equipment & Supplies
    The led screen shows genera error
    you need to reset your printer try doing this
    • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
    • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
    Nov 24, 2008 | Epson Stylus Photo R300 InkJet Printer
    Printer stopped printing. Error message
    Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
    Reset Epson R300/200
    press three buttons to reset the counters
    The buttons are "STOP" "Maintenance" and "POWER"
    or down load the epson utility www.ssclg.com and use the reset counter feature
    The printer will sound like its going to blow up, but thats normal.
    You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
    To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
    Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
    Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
    E16
    press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
    Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
    55 error service
    The 55 error doesn't boil down to one specific problem and most information will tell you the following: 55 ERROR (Internal Communication Problem) 1. Replace DC Controller PCA. 2. Replace Formatter PCA. 3. Replace both at same time. So sounds alot like the main board is starting into a nose dive, but seeing as that particular printer is on the older side, you might be able to find the part on the cheaper side, check out e-bay, they have some HPIII part around. Good luck.
    Aug 16, 2007 | HP LaserJet IIIp Printer
    HP LaserJet 4050 Printer Logo
    728 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
