Question about HP LaserJet 4050 Printer
What is 55.A Printer Error - HP LaserJet 4050 Printer
55.00.00 error message display on the control panel
Error 55 is a major Engine or DC controller issue.
HP LaserJet Enterprise Printers 55 00 0x and 55 0x 06 Errors
Try spares from salvaged printers. Look for "working pull from damaged unit". Of course reconfirm model and spare compatibility.
Printer Works RM1 9371 000 DC Controller As M775 mfp
HP LaserJet DC Controller For M775 Printer RM1 8898 - USD70+shipping
Mar 18, 2016 | HP LaserJet M775DN Laser Multifunction...
Machine error code 55
Sir/madam
Please Follow the Video http://www.youtube.com/watch?v=xig75RXA5qc For Your Printer Brother Troubleshoot
Or Follow Us For On Brother Printer Support
Jan 23, 2014 | Brother MFC-8870dw Wireless Multifunction...
55.0 printer error
Error 55.A is an internal communication error. It typically indicates a communication error between the formatter and the DC controller. The most common cause of this error is normally related to the fuser.
Some steps to try:
1. Turn off and turn on the printer to clear the error message. If the error returns after doing this, then, check external printer connections.
a) Remove the formatter.
b) Reseat any memory DIMMs and EIO cards.
c) Reseat the formatter.
2. If the printer has a duplexer installed, remove it. Turn off and turn on the printer, and see if the error clears. If the error clears, then, the duplexer PCA may be defective. Replace the duplexer.
NOTE: With a worn fuser, the 55.A error usually manifests itself while duplexing, however in extreme cases, the error could appear without a duplexer.
3. Verify that there is no issue with the site power. If the printer is on a surge protector or a UPS, remove it, and plug the printer directly into a wall outlet. If the printer is plugged directly into a wall outlet, try it on another outlet, preferably one that is on a different circuit.
4. Print a PCL configuration page to verify the number of pages since last maintenance. If the printer is close to the 350,000-page service interval, then install a maintenance kit.
If the service interval is not near the 350,000-page interval, then, replace the fuser.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 09, 2012 | Office Equipment & Supplies
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
55 AFTA error
http://www.fixyourownprinter.com/forums/inkjet/25542
The above link has the solution for your issue.
Jul 14, 2010 | IBM 4247 A00 Matrix Printer
Error code 55.0
Hi dcarlson580:
Here is your problem.
55.xx PRINTER ERROR
alternates with
CYCLE POWER TO CONTINUE
An internal communications error occurred.
The page containing the error will automatically be reprinted.
1. Check the power at the printer location.
2. Replace the formatter and/or firmware DIMM.
4. Replace the engine controller board
Hope this helps
Jun 30, 2009 | HP LaserJet 4100 Printer
Error 55
Error 55 (internal communication problem)
  • On the HP 2 series you have to replace both the dc controller and formatter boards. On all other printers it can be several things: DC controller, formatter, main motor
Jan 18, 2009 | HP LaserJet IIIp Printer
G 55 Office Jet error code
Are all the lights flashing....probably a main board.
Inkworks
866-381-0541
Oct 20, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
55 error service
The 55 error doesn't boil down to one specific problem and most information will tell you the following: 55 ERROR (Internal Communication Problem) 1. Replace DC Controller PCA. 2. Replace Formatter PCA. 3. Replace both at same time. So sounds alot like the main board is starting into a nose dive, but seeing as that particular printer is on the older side, you might be able to find the part on the cheaper side, check out e-bay, they have some HPIII part around. Good luck.
Aug 16, 2007 | HP LaserJet IIIp Printer
HP LaserJet 4050 Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
