Question about Samsung Wave S8500 Smartphone
I can't listen music through my bluetooth headset with samsung
    Sergeant:
  • 189 Answers
Can you hear the incoming voice?or can you talk while call is coming?if no then there is a problem in your bluetooth.otherwise there is a problem from your phone check it first.best of luck.
Posted on Feb 10, 2012
Roshan89
  • 271 Answers
SOURCE: how to play music via bluetooth headset in samsung J600
connect the headset...then it will play
Posted on Feb 03, 2009
  • 117 Answers
SOURCE: CAN'T GET MY MUSIC PLAYER TO PLAY VIA MY SBH-170 BLUETOOTH HEADSET
I think the samsung T629 does not have stereo bluetooth. It would have to have a 2.0 class bluetooth profile to play music through the headset
Posted on Jan 20, 2008
  • 6 Answers
SOURCE: i can not play music in bluetooth headset in
hi ajit is here if ur bluetooth is not connect 1st on the bluetooth device n phone bluetooth press the bluetooth suplly key when u not se continous lite after thie search bluetooth n connect password is may be 0000 otherwise some hardware problem because of fall on the surface
Posted on Jan 27, 2010
  • 44 Answers
SOURCE: i purchased samsung wep460 bluetooth
no sorry...its not audio supportable...try purchasing dual stereo bluetooth headset
Posted on Mar 20, 2010
  • 51 Answers
SOURCE: How can i listen music
hi...
Your HM1000 bluetooth is not A2DP support, so cant listen the music via bluetooth.
Posted on Feb 03, 2011
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
Cant listen to music on my motorola i1 & plantronics explorer 233
Plantronics Explorer 233 Bluetooth headset does not support the Bluetooth profile Advanced Audio Distribution (A2DP). Your Bluetooth device and your phone both need to support A2DP profile, without this Bluetooth profile your devices are not capable of streaming music.
Good luck from Headsets Direct!
Oct 22, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How can i listen to music from my samsung r355c via wep460
Turn on your bluetooth headset. On your mobile, turn on bluetooth and search for bluetooth devices. When your bluetooth headset is detected, select it and it will be "paired"with your phone and whenever the headset is turned on all audio output(such as call, music etc.,) can be heard through the headset.
Sai.
Sep 18, 2011 | Samsung WEP460 Bluetooth Headset
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How to listen music via bluetooth headset in samsung GT S3370
Follow the following steps:
  1. Turn ON your Bluetooth Headset device. (A light may lit upon turning it on)
  2. Turn On your mobile phone's Bluetooth.
  3. On your Bluetooth menu of your phone, select "Search for devices"
  4. When finish searching, your Bluetooth headset must be on the list. Else, repeat searching until your phone can find it.
  5. If you can find it, tap Connect.
  6. Now, test your connectivity by playing some music.
Jun 20, 2011 | Cell Phones
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
How to play music of windows to samsung wep 460?
The samsung Wep-460 is designed for data communication, or in other words making phone calls without the hassle of a wire. However music streaming via phone or computer is not supported. It doesn't have that capability. IF you want to listens to music wirelessly using bluetooth, you should get headsets or earphones that has, Advanced Audio Distribution Profile aka A2DP. It is a Bluetooth profile that allows wireless transmission of stereo audio from an A2DP source (typically a phone or computer) to an A2DP receiver (a set of Bluetooth headphones or stereo system). In short you need to have a bluetooth headset that has A2DP
Hope this clears the confusion
Apr 07, 2011 | Samsung WEP-150 Wireless Headset
Bluetooth hansfree connection
hi splash,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Oct 30, 2008 | Samsung WEP200 Headset
How do i listen to music on my plantronics bluetooth that is connect to my samsung blackjack
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the Plantronics Voyager Pro+ and the new Plantronics M50. The Plantronics M50 is a new model which is now available. For more information these two new models, please see the links below.
Plantronics M50
Aug 17, 2008 | Plantronics Explorer 330 Headset
Samsung Wave S8500 Smartphone Logo
190 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
