Question about Ovens
Microwave beeps non-stop. model Jenn-air W225. Electronic control Ms 120 043 99
I have a conventional Microwawe conventional/convectional wall unit W225.
The microwave beeps contantly. I was able to program 30 minutes and left the door to the microwave open and the noise stoped. I am aware this is NOT the solution. Maybe the programming of the microwave Electronic Control panel is the problem. if so, how can i reprogram the microwave again? This problem happened overnight when the microwave was not in use.
Programming time and leaving the door open provides a longer time of silence as I also tried while beeping pressng the keys and after about a minute and three beeps the noise stopped for a couple of minutes.
I would appreciate your help.
watugot
  • 290 Answers
SOURCE: Convection/Conventional in same unit SC302ZS
If this oven works the same as the 302T, the bake element is not used during convection mode, only the convection element.
The cooling fan must come on
The air switch must close
The convection element must be good
I would suspect the element first.
Post back and let me know what you find out.
Posted on Nov 16, 2007
aroracaty2
  • 503 Answers
SOURCE: My kitchenaid 30" built in
what you need to do to fix up oven back again
is that you will have to locate the element of your oven it has develop a lick-age from it some air get escape from it and
the element is the heat provider for your oven that allow it to carry out it function has an oven it is always in silver colour and it is connected to the maize (the wire or the hose from the gas ) which supply power to it
unscrew the oven from the back and trace the wire or the hose that connect to the element
please do this with care to avoided more damage on it
OR
You have one or two possibilities here, one is your control board is going out. The second and most likely problem which is usually associated with this error is that the Latch to the door, or switch is failing causing this message to appear. You need to replace the latch to fix the problem. A new latch can be bought from the place you bought the oven or from RepairClinic.com
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 29, 2010
  • 57 Answers
SOURCE: MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Posted on Feb 25, 2011
  • 794 Answers
SOURCE: F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 12, 2011
mc1bean
  • 3053 Answers
SOURCE: I have a Jenn-Air model W30400BC, electric single,
Hello, iscg
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from
repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Apr 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Beeping and displaying F1. Press stop and 30 seconds later it starts again.
too high temp F1 fault code its either the keypad, or the control board.if the thermostat or oven sensor is bad,it could have got the keypad or control board too hot, and caused the F1
Aug 30, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Microwave on counter making wall oven change
ok the microwave has magnetic fields that may be messing it up only way is to turn microwave off or move it at lease 1 meter away from oven let me know how that goes's for you
Dec 30, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
My Jenn Air 30 in oven
For Jenn-Air ranges, this is a fault code for a defective Electronic Range Control (ERC) and/or membrane (keypad). It is usually a bad membrane that causes this problem. If the membrane has a small ribbon cable connecting it to the ERC, you can sometimes disconnect it, clean the connections, and reinstall to correct the problem. The problem may also be as simple as a button on the keyboard stuck somewhere. Worst case scenario: you will have to replace the entire ERC and membrane altogether. For pricing information, you can find replacement parts at searspartsdirect.com or repairclinic.com. Just type in your model number in the search menu and there will be a parts index for you. The membrane and ERC are usually sold separately. I hope this helps you.
Mar 02, 2008 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
162 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
