Nead wire diagram for power leads
I can not work out the wires that come from on of button to motherboard
  • 807 Answers
Which motherboard, make and model number and Version number if possible
Posted on Feb 10, 2012
atlasuk2007
  • 85 Answers
SOURCE: reset/power/led etc..lead connections
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
Posted on Aug 05, 2007
informatica
  • 1114 Answers
SOURCE: wiring diagram for intel desktop mother board D865gbf
Hi - You can download the manual from the link underlined in blue below:
D865GBF
See page 43:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Jul 29, 2008
SOURCE: diagram of motherboard "kvm266pm-u"
The website doesn't work, it says its unavalible.. any more help????
Posted on Sep 05, 2008
teknowolf
  • 207 Answers
SOURCE: connecting startup leads to ABIT NF7 motherboard
Below is a link to the manual for this motherboard, It should be able to show you where each of the leads on your dislocated panel wires go to.
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=247&model=8&product_name=NF7
Hope this helps
Thanks
Dave
Posted on Nov 20, 2008
rockitman187
  • 2559 Answers
SOURCE: case front panel to motherboard wiring
Here is a link to the motherboard manual
And here is the hook up
Posted on Jun 03, 2009
I plugged in everything and the computer won't start. I'm sure the buttons are working and so is my power supply. It's a new board it can't be broken.
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 29, 2012 | Gigabyte Ga-h61ma-d2v Motherboard...
Emachine w3107 wiring diagram
Good luck on finding a wiring diagram. Usually those plugs represent the Power Button, the Hard Drive and the other sometimes represents a reset button. If you remove the cover and sit the computer on it's side, take a flashlight so you can see inside at the motherboard. If you look from where the wires come from on the front they usually stick into little prongs on the side of the motherboard. The motherboard will have little written identifiers such as hdd for the hard drive light, pwr for power or power reset, fan for fan, etc.
Also sometimes if you look on the little piece at the end of the red, white and black wires where it plugs into the motherboard prongs, sometimes it will have writing on it as to which one it is.
Mar 24, 2012 | Computers & Internet
I have disconnected all th ewire from my motherboard and i have installed all wire but unable to connect pw button,reset button,HDD led wire and anothed LED wire please tell me how can i install them in...
Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.5 Connect the power cable to the back of your computer, and turn the computer on.
  • Oct 14, 2011 | ASUS P5PE-VM Motherboard
    How to link case wires on the mother board? I've lost the manual and i don't find any stuff on chaintech website...
    hi
  • Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.
  • Step 2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.
  • Step 3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.
  • Step 4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.
  • Step 5 Connect the power cable to the back of your computer, and turn the computer on.
  • Jun 30, 2010 | Chaintech 9PJL APOGEE Motherboard
    Pulled out power and reset wires. Power button not working. is th
    do a online search for your motherboard company. and type diagram.
    Nov 15, 2009 | Soyo SY-K7VME Motherboard
    I nead a wiring diagram for a 535 on a 1997 e39
    You need to go to your local BMW Dealership and order a Bentley® Manual for quite a few of the wiring diagrams, but now BMW has them on their library of wiring diagrams for Technicians to print out if they're working on a particular area for a short or open circuit.
    Perhaps you could explain as to what part of the vehicle you're working on and as to how much details you need insofar as the wiring diagrams you're looking for goes.
    "00 Buck"
    Nov 06, 2009 | BMW 535 Cars & Trucks
    Powerbutton connection wires were disconnected from motherboard
    Look in the manual there is a diagram and pin connections for each wire.
    Feb 06, 2009 | E-Machines D2046 PC Desktop
    Connecting startup leads to ABIT NF7 motherboard
    Hope this helps
    Thanks
    Dave
    Nov 20, 2008 | Abit Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
