Question about Xerox WorkCenter PE120i All-In-One Laser Printer
How to reset toner counter on workcentre pe120i
  • 2072 Answers
SOURCE: soft copy of the printer
The guides can be located at Xerox.com under documentation. They can be downloaded easily
Posted on Jun 05, 2008
tbirdfan1
  • 3051 Answers
SOURCE: how can you reset the waste toner counter?
Hello there :
in the main menue of the printer there is a option that lets you reset it to zero but if this is a buisness printer you might have to have the company come and set it for you cause theire somtimes is a code that is entered to get to the main menue
Posted on Oct 23, 2009
  • 17 Answers
SOURCE: unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Posted on Apr 30, 2010
  • 79 Answers
SOURCE: My Xerox Workcentre PE120i screen
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Posted on Dec 20, 2010
  • 569 Answers
SOURCE: Need drivers for Windows 7
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Posted on Feb 15, 2011
I have a xerox workcentre PE120i that displays "scanner locked".how do i unlock it
There is a lock switch below the control panel. When the all-in-one is first shipped, there is a label that wraps over the switch and up to the control panel. When the label is gently pulled out, it moves the switch forward into the unlocked position.
The switch is below the area to the right of the frequently-dialed numbers short-cut buttons. To see a picture of the approximate location of the scanner lock, see page 2.3 of the MFP User Guide (this is page 29 of the PDF). The manual is available on the WorkCentre PE120/120i support page in the Documentation section: http://www.support.xerox.com/support/workcentre-pe120-pe120i/documentation/enus.html?operatingSystem=win10x64&fileLanguage=en . The direct link to the manual is currently http://www.support.xerox.com/support/workcentre-pe120-pe120i/file-redirect/enus.html?operatingSystem=win10x64&fileLanguage=en&contentId=53827 .
I hope this helps. If the scanner lock is in the unlocked position and you still get the error, then there is probably an internal problem. Whether this is a problem with the hardware or a sensor is unclear. If your unit is under warranty or covered by a service plan, contact Xerox or your printer/copier service provider.
Mar 28, 2018 | Xerox Office Equipment & Supplies
Would you please tell me how to reset xerox workcentre 3210 cartdridge chip?
Hi Marco,
They have a chip in them and can't be fooled so to speak by topping them up.
You can get toner and chips off ebay if you do a search for your model...
refer to link for an example...
http://www.ebay.com.au/itm/Hi-Yd-Toner-Refill-Reset-Chip-for-Xerox-WorkCentre-3210-3220-106R01487-/261253227411
Oct 26, 2014 | Xerox WorkCentre 3210 - Multifunction -...
Need drivers for Windows 7 for my xerox workcentre pe120i
Feb 15, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
My Xerox Workcentre PE120i screen says [no paper] "Add paper". but the tray is full of paper. What do you suggest I do?
4) Put in paper
5) Try and print!
Regards,
sjstore2
Dec 20, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Unlock scanner
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
clear.gif UNITED DATA TECHNOLOGIES INC
8825 NW 21ST TERRACE
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
clear.gif MONARCH ELECTRONICS INC
SUITE 319
1440 79TH STREET CAUSEWAY
NORTH BAY VILLAGE, FL 33141
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
clear.gif LASER PRINTER SOLUTION / FIX A FAX CORP
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
SUITE 130
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
clear.gif ADVANCED BUSINESS COMPUTERS
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Sep 23, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCentre PE120i
First unplug power cord for 15 minutes and see if this clears the error.
Inspect the inside of the machine, remove the toner, check deep inside and put toner back.
Ensure that all ports are closed.
If you still get the error , as the machine is new, call the service support number listed on the owner manual.
Sep 09, 2008 | Xerox Office Equipment & Supplies
Soft copy of the printer
Jun 03, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
119 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
