Question about Samsung HC-R4755W 47" HDTV
Flickering Screen I have a 4 month old samsung HC-R4755W CRT projection tv, not under warranty anymore since I purchased it used. After about a half of an hour when the TV warms up, images on the screen, especially dark ones start flickering. Any idea on what is causing it? Or how to fix it? How much it will cost?
    New Friend:
  • 163 Answers
Soon the picture going to go to black screen, you got somes capacitors bothering, you better to call a tech now that he can see the problem, later will cost you more..good luck ps the picture many times tell to the tech whats going on.
Posted on Aug 07, 2006
SOURCE:
How do I remove the outer case, shell, on a Samsung hc-r4755w projection TV? Need to get to the back of the screen to clean it, cat puked down front of TV and got behind screen
there are two screens back to back and I think if you look from back with rear cover removed you will find the debris is between them.
Not going to be easy or simple to deal with.
Oct 25, 2012 | Televison & Video
My Akai pt5499HD has no picture to it and i just replaced the flyback transformer to see if that was the problem. any suggestions?
You need to have copy of service manual for this tv and Samsung PT5499HD service manual will work on your Akai tv as both has same circuit.
Aug 26, 2010 | Samsung HC-R4755W 47" HDTV
My convergence wont adjust on the blue and have no blue in screen
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Samsung HC-R4755W 47" HDTV
Samsung HC-R4755W turns on and off by itself.
Have Capacitors checked in the power relay circuit, also if you have young children who like to push the buttons on the front of the set make sure none of the buttons are sticking inward or stuck in a pushed in posistion. More then likely it might be caused by a faulty System control board which we call the signal board, or bad connections on the power supply, Have a tech check the connections on the Flyback transformer and the High Voltage Deflection Area on the HV Power supply. I believe you have Cold Solder Joints in the HV Power Supply.
Hope you this helps you..
Apr 21, 2009 | Samsung HC-R4755W 47" HDTV
Cracked Lenticular screen
See:
http://www.avsforum.com/avs-vb/showthread.php?t=780806
and
http://www.avsforum.com/avs-vb/archive/index.php/t-783948.html
How old is that TV?
Order from here:
http://www.samsungparts.com
and specifically:
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP67-00227D&search%5Fmodel=HCR4755W
Wow! I think that's a rear projection TV, so it may be time for a new one!, as the part is about $175 + shipping, + installation + your time, + they break pretty easily.
Good luck.
Mar 09, 2009 | Samsung HC-R4755W 47" HDTV
Yellow colored screen
This is a problem with the CRTs(picture tubes) or the coolant chamber(s) of same. The cost to replace the affected parts with be quite high. Expect to spend $400-600 to replace the CRT(s)
michtech
Feb 19, 2009 | Samsung HC-R4755W 47" HDTV
Picture problems and need service manual.
http://www.justmanuals.com/samsung-projection-receiver-hcr4755wx-parts-service-p-25530.html
$9.99
Apr 19, 2008 | Samsung HC-R4755W 47" HDTV
TV won't turn on or stay on?
no solution, Did Samsung get me for 999.00 plus tax?
Mar 30, 2008 | Samsung HC-R4755W 47" HDTV
Tilted Screen
Yes, there is a tilt adjust,but you should have service manual to guide you....it requires some diassembly / access in back of set.....................T.
Dec 20, 2007 | Samsung HC-R4755W 47" HDTV
Samsung HC-R4755W 47" HDTV Logo
159 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
