Question about Keurig Platinum B70 Coffee Maker
Leaky Keurig B70
Its leaking when the reservoir is attached to the machine!!! Please help I just bought it and want it fixed!!!!
  • 1,511 Answers
Return for replacement. Factory problem. Many have experience this condition.
Posted on Feb 07, 2014
  • 25 Answers
SOURCE: Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Posted on May 14, 2009
cmccune04
  • 213 Answers
SOURCE: leak water tank
I can get that gasket for you. I do not have it listed yet but give me about an hour and it will be up and ready!
I specialize in keurig brewers and thier parts
http://iwantsweetdeals.com/
Posted on Jun 14, 2010
espressonist
  • 1711 Answers
SOURCE: How do I drain water
If leave it for a couple of months without using it, later on when you will need to use it again it by 95% it will be stuck. Their many parts related with water , 2 pumps, valves, jet pasages that even one of this goggled with a sales part then the machine will need complete desaesemble manual descaled and put back together.
So I sugest to find a way so that the machine keep work atleast once a week or even lent to a friend istead of put it on the shelf for long time.
Posted on Aug 20, 2010
espressonist
  • 1711 Answers
SOURCE: water leaks out the bottom
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler . All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Posted on Sep 27, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
MY KEURIG B70 IS CONTINUALLY PROMPTING TO "PRIME"
Hi, Lauren..
You can download another manual here.
Cleaning any coffee brewer is essentially the same. The easiest way is to brew one or more pots of white vinegar... it'll stink up your kitchen, but it's effective at removing build-ups and mineral deposits. Be sure to follow up these "vinegar brews" with several "plain water brews" to remove all the vinegar!
Also, if your water reservoir isn't clean (open the lid & do a finger swipe), you can use a brush to clean it or - what I do - wad up a paper towel or two, attach it to the end of a long-handled wooden spoon, and use that to get down deep into the reservoir & scrub it as much as you can before the vinegar treatment.
Alternatively, you can spend $3 or $4 for packaged cleaning compounds at stores like Williams & Sonoma.
Mar 02, 2011 | Keurig Platinum B70 Coffee Maker
Broken O-ring floating in water reservoir. Where does it go? Should I replace it? No leaks anywhere. Machine works fine otherwise
The o-ring you found floating goes around the black circle of plastic that surrounds the water inlet valve at the bottom of the inside of the reservoir. It's only used to create a seal when you're using the attachable water filter. If you're not using the attachable water filter, you don't need to replace the o-ring.
Jun 06, 2010 | Keurig B70 Coffee Maker
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Apr 23, 2010 | Keurig Platinum B70 Coffee Maker
The Water Reservoir is leaking on my keurig coffee maker.
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Mar 23, 2010 | Keurig B70 Coffee Maker
Never gets ready, keeps shutting off.
Try using a straw. Use it to blow thru the hole where the reservoir attaches. I tried this on my B40 and worked.
Feb 23, 2010 | Keurig B70 Coffee Maker
Where can I get a replacement reservoir for my B70 Keurig?
I bought an open box B70 that said on the box that it was complete, but when I got it home it was missing the reservoir. I emailed Keurig and they said let us know the serial number and we'll send you one free of charge. Dunno if it'll work in your situation but the company is so customer-friendly, I'm sure they'd offer a fair solution.
Oct 14, 2009 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
115 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
