Question about Lenovo Computers & Internet
"to boot to the rescue and recovery environment , press F11" and a blinking cursor
After installing Rescue and Recovery 4.23 in Vista the following message appear on windows start up: "to boot to the rescue and recovery environment , press F11" and a blinking cursor
Factory settings sony vgn-n31z/w
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
Oct 03, 2012 | Sony Vaio VGN-N31Z/W
Reset to factory without disk
which operating system ?
hope this helps
Sep 30, 2012 | Sony VAIO VGC-JS210J/B 20.1 in. PC Desktop
I want to recover my sony vaio laptop with windows 7 OS, i want to get it back to original state to delete all personal installed programs. pls help
hope this helps
Sep 29, 2012 | Sony Refurbished White 14" Vaio...
Vaic t200 password needed to unlock but none offered. please help
Hi! Welcome to www.fixya.com.
Recover From Within Windows 71Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
2Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
3Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased. The computer will restart and the recovery process will begin. When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition1Turn on or restart your Sony Vaio computer.
2Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine. If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
3Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter." The VAIO Care program will appear on your screen. Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs1Insert the first recovery disc in your optical drive and restart your Sony Vaio computer. The total number of recovery discs varies based on your Sony Vaio computer. The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
2Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
3Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
4Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete. The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system.
Read more: How to Recover Factory Settings on Sony Vaio Computer with Windows 7 ' eHow.com http://www.ehow.com/how_7680511_recover-vaio-computer-windows-7.html#ixzz1SY1sA7Sg
Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Computers & Internet
Forgot the password do you have a defalt password that would help me get into it
To boot to the Rescue and Recovery Environment, Press F11 at startup or find a good password recovery program usually the recovery is cheaper way to go but you loose your data.
Mar 11, 2011 | Lenovo IdeaPad S10e Netbook
Lenovo SL 500 not booting after startup only black screen with cursor is seen
Dude,
Most of the time, the machine booting with the blinking cursor indicates a problem with the HDD itself.
You can do the following:
1) Reseat the HDD
2) Check BIOS boot order and see if the HDD is still recognized at BIOS level
3) Load the BIOS defaults (F1 at boot, then F9, F10)
4) If the HDD is detected at BIOS, try to access Rescue and Recovery on the HDD (F11 key at boot) and try to reload Windows.
5) If problems persist, I'd highly recommend replacing the HDD!!
Apr 17, 2010 | Lenovo ThinkPad SL500 Notebook
After Rescue n recovery with F11, i got error messeges & all data
probably not easiest way is get a cd and do a fresh install
Jul 21, 2009 | Lenovo ThinkPad T61 Notebook
Black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
May 15, 2009 | Compaq Armada E500 Notebook
Ibm thinkpad tablet won't boot, says insert set up cd rom which i no longer have
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. thanks and have a nice day J-
Dec 10, 2008 | IBM ThinkPad X60 Tablet PC
Computers & Internet Logo
1,324 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
