Question about Onkyo HT-S5100 Theater System
ONKYO HT-RC230 SURROUND SOUND WONT WORK
NO MATTER WHAT ONLY ONE SPEAKER HAS SOUND
brandonboyce
  • 84 Answers
SOURCE: Onkyo HT- S790 installation manual
You can find manuals for Onkyo products here http://www.onkyousa.com/download/own_manuals.cfm
Posted on Jul 23, 2007
SOURCE: Problem with Onkyo HT-SR700
Can you explain how you have the DVD player connected to the reciever and what the label on the jacks read on each.
Posted on Sep 16, 2007
SOURCE: Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Posted on Jan 01, 2008
You might have blow the fuse for those channels.
Posted on May 05, 2008
SOURCE: Onkyo HT-SR800 the surround speakers are not blasting
I had the same problem and fixed it by manually setting the surround speakers changing the Level Cal to +12dB. You will immediately notice a significant increase in volume and may need to back down on the dB's. What a diffence it makes!
Posted on Dec 17, 2008
Onkyo HT-R693 (HT-S7700) receiver will play video but no audio on Netflix and YouTube. However, sound comes through when connected to Comcast cable and even Pandora. I have tried the different channels...
  • Check your cable connections
  • set the input selector to the proper component sources your using.
  • set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
Mar 08, 2015 | Onkyo Audio Players & Recorders
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I have purchase an onkyo HT-RC230 receiver. I want to connect a Directv R16-500 DVR & RCA L32W22 TV. Directv satelite service is currently connected to the DVR and DVR is connected composit S ports of ...
This is a rather uncomplicated satellite receiver, and basically only has a left/right audio out.
You can hook these into any of the stereo type inputs on the HT-RC230.
This receiver is also the "wal-mart" brand of Onkyo (not their best stuff) - so I suggest you take the L/R audio out on the DVR and put it into ANY available (cd/tape/dvd) stereo input on the receiver.
You aren't going to get better sound out of any specific input.
Feb 21, 2011 | Onkyo Audio Players & Recorders
ONKYO HT-S780 B SPEAKERS
Your symptom sounds as though you may have to turn off any surround sound settings that you have selected in the other modes.
Most amplifiers use the surround portion of the amplifier to power the B channel speakers.
Since you have sound when using the radio portion, I would try turning off the surround mode. For example try turning the amplifier to just stereo and see if that gets the B channel speakers to work
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 22, 2009 | Onkyo HT-S780 System
Surround sound speaker outlets are not working
Hello, I am sorry about your issue. If the speakers work on other terminals then it sounds like a problem with the receiver. It would need to be serviced or traded in. Please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jun 24, 2017 | Onkyo HTR500 Receiver
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Sep 14, 2008 | Onkyo HT-SR800 System
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
Dec 31, 2007 | Onkyo HT-S680 System
Sep 16, 2007 | Onkyo HT-SR700 System
Onkyo HT-S5100 Theater System Logo
108 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
