Question about SATO GT408e Printer
Error 11 on sato gt408e
What is head error11
3 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Sato GT408e
there is a sensor you need to adjust (MEDIA SENSOR), depending on what type of labels you are using.
1-labels wit a notch on the side : move sensor all thte way to left ( if standing in front of printer)towards the notch.
2- labels with a seperation brtween each one, move towarrds middle.
Take a look at this link and look at page 28 for a better understanding. ( zoom to 400%)
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Posted on Oct 22, 2007
facebook484
SOURCE: Sato GT408e
free email support for Barcode printer help and downloads for creating barcodes as well as zebra barcode printer software can be found for free at:
http://www.utouchpos.com/magento/index.php/support/
we are a ISP for intuit and provide not only sales and support but also free email tech support even if you are not a current client.
Posted on Sep 16, 2012
Sato 408E problem
Using direct thermal labels it can dirt the printhead and platen roller, you must clean them with isopropyl alcohol and a flannel. Also adjust the darkness to less value to best print.
Roberto Martinez
Jun 29, 2009 | SATO CL408e Thermal Printer
I have a Sato M-8485S printer and changed my print head 2 times making sure i dont scratch it while i put it on and changed de rubber roller. But still it is well dark at the bottom but light dark after...
Lo mas probable es que requiere que la cabeza sea bien ajustada en su posicion. Lo mejor es que la ajuste un tecnico calificado en impresoras SATO. The most probable is that it requires that the head is tightened into position. The best thing is that adjust by a qualified technician in SATO printers.
Jun 04, 2009 | SATO M-8485Se Thermal Label Printer Print...
Sato thermal printer will start printing, then stop saying that the head is open
Esta impresora utiliza un pequeño switch que detecta cuando la cabeza esta abierta. Identifica donde esta este switch y verifica si no tiene cables rotos o esta dañado. This printer uses a small switch that detects when the head is open. Identifies where the switch and check if it has no broken wires or damaged.
Mar 05, 2009 | SATO CL408e Label Printer
Need to determine the ip address for SATO M8485SE
2 ways you can determine the IP setup.
1: You can use Sato's ip net software, available from the Sato web page. This software will discover the printer on the network through a connected PC.
2: With the NIC carad inserted, the IP address can be set through the front panel by depressing the line key while powering up the printer. You can scroll through to the settings and change to the needed IP address
Dec 03, 2008 | SATO GT408E Thermal Label Printer
Sato 8485se problem whit the papaer ajustment
1-go to the menu
2-media settings
3-Label Lenght ( adjust lenght here) back out and save settings
Aug 26, 2008 | SATO GT408E Thermal Label Printer
Printer Error(Sato Cl 408 e)
PROBLEMA EN AJUSTAR EL CORTE DE LA ETIQUETA, CUANDO LA IMPRESORA SENSA LA ETIQUETA, ESTA QUE CORRIDA HACIA LA PARTE DE ATRAS DEL CABEZAL HACIENDO NECESARIO UN FEED PARA PODER CORTAR LA ETIQUETA
Jul 05, 2008 | SATO CL408e Thermal Printer
Sato GT408e
Oct 16, 2007 | SATO GT408E Thermal Label Printer
Printer problem
check baud rate on NIC card (pull out NIC), against COM settings on PC. they must match. 9600 usually works
May 22, 2007 | SATO CL408e Thermal Printer
SATO GT408e Printer Logo
148 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
mukhtar21 shaikh
mukhtar21 shaikh
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
