Question about Keurig B50 Coffee Maker
Cuisinart Coffee maker LCD Screen flashing Not Ready
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my keurig coffee maker just flashes not ready and
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
  • 58 Answers
SOURCE: coffee maker is indicating not ready add water
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
  • 10865 Answers
SOURCE: What will cause the message NOT READY to show on
Hi acein... it shows not ready until the water for one cup is hot. Usually after about a minute it will be ready. Sometimes you have to open and close it to get it to indicate ready. Joe
Posted on Feb 23, 2011
My cuisinart automatic grind and brewthermal shuts off every minute or so it douse not brew strate through.
HI,
• Remove the hopper from the unit
• Lift coffee channel cover
• Clean out coffee chute
• Replace channel cover and hopper
• Your coffeemaker is now ready to brew again
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
May 13, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart coffeemaker won't brew
A common problem that can occur with the Cuisinart coffee maker is it will stop brewing, even when there is water ready to be transformed into coffee. The machine still turns on and works like it should, but does not continue brewing an entire pot of coffee, and acts like it has finished brewing even when there is still water sitting in the bin. This type of problem is pretty common among various coffee makers, and usually occurs when there is a problem inside the machine.
One of the best ways to fix this problem is by flushing the coffee maker out with a vinegar solution, which can be made with equal parts of vinegar and water. It should be poured in the same place as the water that is ready to be brewed, and will help to clear out the machine and make it ready to start brewing again. This problem is usually caused by calcium building up within the machine, and the vinegar helps to clear out any blockage to help it start running smoothly again.
Nov 01, 2017 | Cuisinart Coffee Makers & Espresso...
Cuisinart DBG-500 has - -- on screen won't do anything
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke dwn - you wouldn't be upset if your $15 Mr. Coffee broke eveyr year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Dec 15, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart Coffee maker: no power coming into unit. When I took the bottom off to look at the circuit board I shorted the circuits and saw that there is power coming into the board, but it isn't getting...
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Sep 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I don't know how to set the time on my Cuisinart Automatic Grind and Brew coffee maker. HELP!
When the machine is plugged in, screen will display 12:00.
Press and hold the "HR" and "MIN" buttons until the numbers flash.
Then press the "HR" and "MIN" button to scroll through the numbers.
/Mirran
Jul 08, 2008 | Cuisinart Coffeemakers
Keurig B50 Coffee Maker Logo
283 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
