Question about Vacuums
Steam cleaner YQ5888 no steam
YQ5888 steamer cleaner it heats up but wont steam
  • 121 Answers
SOURCE: how do i put belts on a bissell powerbrush steam cleaner?
If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
Posted on May 07, 2009
  • 4088 Answers
SOURCE: Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Posted on Sep 09, 2009
heatman101
  • 43501 Answers
SOURCE: Shark Steam Mop - Gray/ Purple Vacuum: My shark steamer is heating up but not steaming. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Posted on Sep 03, 2010
heatman101
  • 43501 Answers
SOURCE: I have a shark steamer, light is on but no steam. ...
Nope...no cleaning to it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
heatman101
  • 43501 Answers
SOURCE: bissell handheld steamer froze in the car and wont blow out stea
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
afdda
Posted on Sep 30, 2010
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
My polti steam cleaner wont work when i click trigger
Check the wand and line for calcium build up especially in the nozzle. Hard water will deposit a lot of calcium in the system, which needs to be cleaned regularly to keep it running freely.
Aug 25, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
No steam from steamer
check for blockage in steam nozzel all the way back to the water reservoir
May 09, 2012 | H2o TR220002 Steam Cleaner
My euro pro s3300 shark steam cleaner heats up but doesn't steam when you press the button. It is gray in color and the light turns on and is hot to the feel. What is the problem can it be fixed by me or...
if you use it for more than an hour theres an automatic kill switch located on the inside designed to make you buy another one , but you can take it apart and hardwire it to bypass that kill switch , and your steamer will work once again.
Feb 23, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Euro-flex monster baby 1000 watt will not release steam
try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
My steam cleaner will not get hot enough any more. It is only a year old.
probable scale problem in boiler. Try using coffee machine de-scaler add to steamer heat and rinse. De-scaler available from most stores selling automatic coffee machines. Or it may be an element failure.
Sep 13, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
