Question about Pioneer CDJ-800 Turntable
My cdj 800 plays cd but with crackling sound but it takes awhile to load.
SOURCE: CDJ 800 Has no power
this guy don't know what he is talking about,the cdj800 does have a fuse,if you open the unit up just make sure it's unpluged,if the fuse is blown replace it with one of the same rating,it's right next to the switch inside the unit,it's very easy to take apart just 5 screws,I have one that won't power on also but it's not the fuse,but yours could be,just check it out and don't be afraid just be careful when handling electronics so that you don't send static charges into the chips.
Posted on Feb 05, 2009
djproaudio
  • 515 Answers
SOURCE: pioneer cdj 800 problem
More than likely you have a damaged CD transport, or needs to be calibrated or professionally cleaned. I would suggest taking it to a service center.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
djproaudio
  • 515 Answers
SOURCE: my pioneer cdj 800 simply wont work!!
Your traverse assembly is damaged, and will need to be replaced. Although self-repair is not recommended, you can buy the part and bring it with you to a service center for replacement.
Pioneer CDJ800 Part - CD Reader for CDJ800MK1
Pioneer CDJ800MK2 Part - CD Reader for CDJ800MK2
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Posted on Apr 30, 2009
djproaudio
  • 515 Answers
SOURCE: Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Posted on Aug 30, 2009
SOURCE: Pioneer CDJ-800 Vinyl Mode Broken
Same thing here too. The Vinyl mode stops the player and when I press it out of Vinyl mode, it works fine. What is causing this problem? I took it apart and cleaned the insides, which were gross, I think someone spilled something on it. :-(
Still, I cleaned the track and put it together and still it doesn't work? Might be time to take it to the shop.
Posted on Nov 24, 2009
It takes too long until he read the tracks.i have to mention that the other one player read the same disc much faster
hey,
there is nothing wrong with ur CDJ, some player takes time to play disc. Also, depend how old are ur CDJ's and how much u have used laser of ur CDJ's.
thx,
djajay
May 13, 2010 | Pioneer CDJ-200 CD Player
CDJ 800 MkI. When I put in a CD, it makes a sound
Bits of paper / pieces of CD lables can get stuck inside and rub on the CD causing the noise you are hearing
http://stores.ebay.co.uk/methleykev
May 10, 2010 | Pioneer CDJ-800 Turntable
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
My cdj 800 mk1 wont load/play cds ?
hi there,
you need to clean compartment of the CDJ, there must be dirt which dont let the cd play, also let me know it you get any error code.
djajay
Oct 29, 2009 | Pioneer CDJ-800MK2 Turntable
Not reading cd's
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! You can get a replacement unit, here http://1200s.com/Store/PARTS-PIONEER-CDJ-800/c271_461_491/p320015/Pioneer_-_CDJ800_CD_Mechanism_w/Pick-up_Assembly/product_info.html
You might want to bring this to a pro sound shop for repair. I'd order the part by myself and bring everything at the repair shop...
Oct 10, 2009 | Pioneer CDJ-800 Turntable
When switching on the unit and loading a cd it can take a long while to register the cd then it will play for a few seconds then stop. this will clear after a few minutes and play as normal, however if i...
No this is not a common issue. If your traverse assembly is not damaged, then it's possible the loading motor might be the issue.
In either case, I would suggest professional assistance.
Hope this helps.
- OPTiC
Master Tech
Jul 18, 2009 | Pioneer CDJ-800MK2 Turntable
I have a problem with my cdj mk2 800
I could not understand what you just wrote.
Yes, a video would be best.
Although it sounds like the loading motor might be faulty.
- OPTiC
Pioneer DJ Repair
Pioneer Parts
DJ Parts
Pioneer DJ Equipment Sales
Mar 27, 2009 | Pioneer CDJ-800MK2 Turntable
Cdj 800 keeps skipping
Manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/290519777CDJ-800_Manual.pdf
Contatc Pionner for nearest authorized service center - they will either help you or be an a--hole
Jun 01, 2008 | Pioneer CDJ-800 Turntable
Cdj 800
CD reader sounds like it's stuck. You might have some debris inside, or the reader might need to be replaced. Not an easy fix, and I would suggest contacting a service center for assistance.
DJPROAUDIO
TWEAK AV LAB
Jan 13, 2008 | Pioneer CDJ-800 Turntable
No sound from CDJ-800 MK2
Are you getting error messages? Running in thru LINE? Is not on mute? The possiblity of both not playing would lead to process of elimination.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
106 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
