Question about HP Office Equipment & Supplies
My Deskjet4360 is a few months old. I did some extensive printing and when finished could not shut off the printer. I finally pulled the plug. The next day the on/off button would not work
    Brigadier General:
  • 6,966 Answers
Initially, pls check the power adapter. Some versions of HP uses a power adapter that has two (2) voltages. You would need a DVM to check these DC voltages. If the voltages are not there, then t is the adapter, if they were measured, then the internal circuitry of the printer is the issue. It would require fair familiarity with electronic circuitry & components to establish repair. otherwise, the services of a qualified professional may be needed.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 23, 2008
    Genius:
  • 2,035 Answers
  1. Check for any loose connection between printer and power source. Change the power cord and connect it directly to the power supply (eliminate any Pass through devises such as Surge protector). Check if the printer powers on. Print a demo page to confirm the functionality of the printer.
  2. Many Deskjet printers will not power on if the rear access door is not fitted or locked properly. Make sure the rear access door is connected and locked correctly.
Good luck..
    Scholar:
  • 136 Answers
Its the problem with the front contol panel switch
  • ready2helpu Oct 23, 2008
    still u can try removing all the cartridges and all the power connections out of ur device n keeping it shut off for a hour n then reinsert everything n try this reset somtimes solves if there is some minor problem.
Power surge
This is kind of hard to diagnose, but i can try to help you out. I had a problem like this in my own house. A laser printer when it first starts to print it pulls an incredable amout of electricity. Therefor it can make a few things happen. It can make your battery kick in which can be telling the pc to turn off. Or it can be blowing the fuse in your actual circuit panel. To test if you need more power i would run a heavy duty extension cord to the printer and plug it in to a seperate outlet than you can be certain is not on your comptuers circuit. If it works without turning your computer off you know your problem is your electric circuit in your house. I would then call an electrican. If it still does not work after trying the above which i dont see a happening then i would be kind of stumped :)...
Try this above step and let me know. thanks again
Steven.
P.S. my computer worked fine for along time too before i saw any power issues.
Apr 26, 2010 | Brother HL 5140 Laser Printer
Replacement printer will not print. connection all ok computer says connected
It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Won't work after installing new ink cartridges
This can happen to cartridges with attached print heads such as HP, Lexmark or Dell. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | HP DeskJet F380 All-In-One Printer
I have inserted new ink into dell 924 but not printing
Feb 19, 2010 | Dell 924 All-in-One InkJet Printer
I have just replaced all 4 ink cartridges, but printer refuses to admit that any have ink
This can happen to cartridges with attached print heads. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | Epson Stylus CX3810 All-In-One InkJet...
Whenever I turn on the printer, it starts printing past photos on it's own
Go to the Control Panel and call up your printer icon. Double click on the printer and go to Properties. Are there any files listed that is waiting to be printed? If so, delete them. You're only deleting them from your Printer Spooler, not the hard drive. Other than that, Shut Down your computer completely. Pull the power plug and wait for 1 minute, then plug it back in.
Now unplug your printer from your system and the power cord and let it sit for a minute or two. Plug it back in and fire up your system. When your system is finished booting up, turn on your printer and that should end your problem.
Nov 11, 2009 | Epson Stylus NX400 InkJet Printer
Won't shut down, won't finish boot - no functionability
I have had a similar problem since I bought this printer. When I make a copy or scan a document, the printer refuses to print anything else directly from the computer. If I turn offf the printer, I get the "printer is shuttting down" message in the display, however it never shuts down ( I've even left it overnight!) I have to pull the power plug out and wait ~30 seconds and then plug it back in to restore functionality in the print mode. I get some kind of nag screen at start up telling me that I didn't shut it down properly but I have just learned to ignore that. This problem is so consistant that I don't even try to print after making copies without unpluging the main power plug. Another issue you will probably run into is if you install Service Pack 3 on Win XP all your documents will print out in mirror image. HP's lame fix for this is to have you make custom settings in the print manager to remove the mirroring mode from the settings!! I am just about ready to change brands after being a faithful HP customer for over 25 years. They seem to have no interest in fixing known software issues anymore, as their push is to get new devices in the pipeline as soon as possible.
Good Luck
Tony
Oct 04, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
I haven't used this to copy for a few weeks and it won't copy. It won't feed and it won't scan. It locks up and I have to pull the plug to reset it. It will however, print from the computer. Help?
I printed a screen off of the internet. Then I was able to shut of printer sucessfully. I then tried to copy again after I started it back up and it printed. Yeah! I think there was some kind of glitch that was corrected after I printed and shut the printer off. Before, I was only able to shut it off by unplugging the printer.
Jul 18, 2009 | HP Officejet 5610 All-In-One InkJet...
50.2 Fuser Error
Try to reinstall fuser ***'y, located in the back of the printer.
Whem this not solve you're problem you've to change the fuser ***'y.
p.n. RG5-7602 110-127 VOLT or RG5-7603 220-240 VOLT
Apr 12, 2008 | HP LaserJet 2840 All-In-One Printer
21 people viewed this question
Ben Johnson
