Question about Motorola Computers & Internet
How to setup LAN printer over TCP/IP in Windows CE 6.0
I have a Windows CE 6.0 scanner connected to the wireless network, but couldn't find a way to setup a printer to it. Windows CE doesn't have a System Printer / "Add a printer" option anywhere. Any advice? Thks!
  • Official Brand Answer
  • 3,100 Answers
Howdy admin
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Posted on Jan 20, 2015
2 Suggested Answers
  • 5 Answers
SOURCE: TCP HOst Setup on a PDT6846
The host ip setup is application dependant. You'll need to check with the vendor that supplied your PDT6846 5250 emulator.
Posted on Apr 18, 2008
How do I add a printer to the network?
How to create an IP address into your Printer
1, Connect to LAN network
2, Power ON the Printer.
3, Select MENU Button
4, Go to System Settings, then select Network Settings.
5, You can see TCP/IP , View IP ,etc.....
6, Type Your Printer IP address, Subnet Mask, GateWay, etc...
7, That's All......
In different Printer settings will be different.
Now You can add printer into your computer
Go to Control Panel--> Hardware and Sound -->Device and printers -->Add Printer-->Add network Printer-->"If no printer were found" Select "The printer that i want isn't listed" --> Add printer using TCP/IP--> Type your Printer IP address--> Now you can install printer software...
Thanks
Oct 10, 2012 | Canon imageCLASS MF4370dn...
Tip
Setting up Epson Stylus SX515w on a PC.
0 false 18 pt 18 pt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-ansi-language:EN-US;} This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable.
1) Using the Control Panel on the printer, press the Spanner/Screw driver button.
2) Scroll though the menu until you see Network Settings & press ok.
3) In the following menu select Wireless LAN Setup.
4) Then select Advanced Setup.
5) Then select manual Setup & press ok.
6) This guide assumes you are connecting through a router via Wi-Fi, in which case you will need to select Infrastructure Mode and then press OK.
7) Select Search SSID & this will search for your wireless network.
8) If your wireless network is showing, make sure it is highlighted then press OK.
9) Now you will need to enter the encryption type, this will depend on the length of the wireless key. WEP 64 Hex (10), WEP 64 Alpha (5), WEP 128 Hex (26), WEP 128 Alpha (13). Any router that has 8 characters I would normally recommend selecting WPA PSK TKIP UNLESS you know that the key is WPA PSK AES.
10) Now you will need to input the security key depending on which type you have, as advised above.
11) Once the key is in correctly you need to press OK. You will then see a Confirm Settings screen. Press OK on this screen and YOU MUST WAIT 30 SECONDS for the printer to establish a wireless connection with the router. After the 30 seconds please go down to Confirm Settings and press OK. This will tell you if it has successfully connected to the router. At this stage you need to make a note of the IP address. This normally starts 192.168.x.x
12) On the PC the printer will need to be installed, I recommend downloading the driver from here:
13) Once installed go to Start > Control Panel> Printers (This will vary slightly depending you version of Windows).
Right click on the printer, select properties (Printer properties for Win 7). Select the ports tab and add a new port.
When adding a new port select Standard TCP/IP, then click add new port.
NB The Standard TCP/IP port is recommended when assigning static IP address to the printer. (See router documentation on assigning static IP address).
If using a dynamic IP Address I would recommend downloading and installing the Epson net printer port. You can use a Standard TCP/IP port, however when the IP address changes communication between the printer and PC will be lost.
Setting up both port types are the same, once you select add port you will need to enter the IP Address, which we noted down previously from the printer. Once entered keep clicking next, then finish.
You should now be able to print over the network. To use the scanner over the network you will need to open Epson scan settings, (a separate utility to Epson scan) this will need to be set to network and contain the same IP address noted down earlier for the printer.
If you still have issues check your firewall and router settings, i.e. mac filtering etc.
on Dec 11, 2009 | Office Equipment & Supplies
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
I need to know my brother mfc printer ip address
press menu go down to network or lan press ok or set.
choose wired lan for wired network or Wlan for wireless.
choose tcp/ip, choose ip address
Nov 15, 2009 | Brother 6-In-1 Printer/Fax/Copy/Scanner
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
-IP: 10.0.0.1
-Subnet: 255.255.255.0
TCP/IP on iPhone
-Static IP
-IP: 10.0.0.2
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Computers & Internet
Installed my SX515 Epson printer and it will not connect with wifi
Oct 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have a netgear wgps606 wireless print server. I
Manual Configuration of WGPS606 Print Server
Note: Before configuring the printer server please check if you printer is compatible. You may open this link to you web browser: http://kbserver.netgear.com/kb_web_files/N101216.asp.
1. Please make sure that the printer works when connected directly to the computer.
2. Confirm the wireless settings of your router. You should have the SSID, wireless security and IP address of the router.
For NETGEAR routers please follow these instructions to check the wireless settings:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab and you may get the wireless settings on that page.
e. On the left side under Advance setup, click on the LAN IP setup and locate the LAN TCP/IP Setup. Underneath that is the IP address of the router.
Note: If your IP address is 192.168.1.1, then you may use 192.168.1.200 for your print server.
3. Please connect a computer to the print server. At this time, the router is not connected. The printer should be connected to USB1. The power, LAN port and LPT1 should be lit.
4. Assign static IP address to the computer.
a. Click on Start and right click on Control Panel.
b. When the Control Panel window opens, double click Network Connections.
c. Right click on Local Area Connection, then click Properties. When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then hit Properties button.
d. Change the option from Obtain an IP address automatically to Use the Following IP Address and enter the following:
IP: 192.168.0.50
Subnet Mask: 255.255.255.0
Note: Leave the default gateway and DNS addresses blank.
f. Click on OK and then Close. Exit out of all the Windows.
5. Ping the print server.
a. Click on Start and then Run. Type cmd and hit OK.
b. On the DOS prompt, type ping 192.168.0.102. This should give four responses.
c. If it gives request timed out or destination net unreachable, please turn off both print server and computer. Wait for few minutes, then turn it on again. You can also try holding the reset of the device. Then repeat steb 5.b.
6. If you are able to get replies, you may now open Internet Explorer and type 192.168.0.102 on the address field.
7. After hitting go or enter on the address field, it will ask for a login. (Please type in admin for Username and password for Password).
8. Click on Wireless Settings under Setup tab and we need to set the same SSID as your router.
9. Please also select the appropriate Wireless Security and type the network key or wireless password from the router. Then click on Apply to save the settings.
10. When you get back to the page, click Print Server settings.
11. Check Change to and set the following:
IP address: 192.168.1.200 (It should be on the same range as the router. e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). This will be the print server's IP address.
IP mask: 255.255.255.0
12. Click Apply to save the settings. We will get a Page cannot be displayed.
13. Set the IP address of the computer back to dynamic.
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then click on OK.
For Windows 98 and ME:
a. Please click on Start, then Settings, and then Control Panel.
b. Double-click Network then select TCP/IP for the Ethernet adapter. Then click on Properties.
c. Go to IP address tab and select Obtain an IP address automatically.
d. Click on the Gateway tab and delete the numbers under the Installed Gateway.
e. Click the DNS Configuration tab, and then select Disable.
f. Click on OK. Windows will then prompt for a restart.
14. To set up a TCP/IP port to the computer, please follow these steps:
b. Double click on Printers and Faxes.
c. Right click the printer icon and go to Properties.
d. Click Port Tab and click Add Port.
e. Select Standard TCP/IP port. Hit OK or Next.
f. In the field for Printer Name or IP Address: enter the IP address of the Print Server and click on Next.
g. Select Custom and then click Settings.
h. Under Protocol select LPR, and for Queue Name, type L1 if printer is connected to the print server USB port 1 and L2 if the printer is connected to the 2nd port.
i. Click on OK, then Next, and Finish.
j. Lastly, please right click on your printer icon and select Use Printer Online. If this is not an option, disregard it.
15. Check if you can print through the print server.
16. If it is not printing, then please try to connect the print server to the router and check if you can print. If it can, then there might be a need to re-do the steps for wireless configuration of the printer server.
Mar 29, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Netgear Print server
IP: 192.168.0.50
Dec 18, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Computers & Internet Logo
88 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
