Question about Garden
How do i adjust the carbourater in a poulan p40 18 wt
Adjust Carb?
  • 12 Answers
SOURCE: Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Posted on Mar 15, 2009
SOURCE: adjust high low screws on carb.
I just finished looking at mine and I think they made it that way so back yard mechanics dont tinker with it. If there is a Poulan dealership in yout area that would be the place to get it.
Posted on Mar 27, 2009
  • 124 Answers
SOURCE: Require high and low carb settings for Poulan 2050
You will find that saws of recent production allow very little if any adjustment for the consumer. The carb will either have limiters which allow you less than one turn of adjustment or they require a special tool to make the adjustment. You will need to take it to a dealer to have these adjustments made. This is your government in action protecting you from that evil pollution your chainsaw spews out.
If you are able to adjust, then gently seat each screw and open 1 full turn. This should allow the unitto start and you can adjust from there. If it will not start you probablu need carb repair or replacement or you have other problems.
Posted on May 11, 2009
  • 597 Answers
SOURCE: how to adjust Zama carb on poulan pro
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Posted on Jun 28, 2009
  • 302 Answers
SOURCE: I have a Poulan Pro PP4218AVX 18
there should be 2 adj. screws going in to the carb marked L and H. Try turning the H jet in a little at a time and see if this helps. Or you can slowly turn it in all the way until you feel it stop. don't turn it any further in or you will damage the needle valve tip. Turn it out 1 1/2 turns and start the saw. It should run good at that setting. If not then adjust the screw in or out until it runs faster.
Posted on Aug 27, 2009
Testimonial: "That was the problem/solution. Thanks a million!"
How to adjust zama carb
start with your screws turned in. adjust the high screw to 1 turn and the low to 1/2 turn. this should get unit running. once running then you can fine tune the carb
Oct 09, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
How to adjust carb. on a poulan chain saw 38cc model 2175
If the carb is adjustable, it will have two small screws on it ( maybe covered with a plastic cap) One is low speed and the other is high speed. Adjust very little at first.
Sep 24, 2014 | Garden
How do I adjust timing on a poulan pro snowblower
Factory Set, you can not truly adjust the Timing, most people find that the Carburator or Spark plug will fix 99% of everyone's problem
May 13, 2014 | Poulan Garden
Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Aug 08, 2011 | Poulan Garden
How do you adjust the carbuerator
Most of the new carburetors have screws with special heads that do not accept tools most DIY's will have. These carb. adjusting tools are restricted to dealers only. I can't speak for all dealers but many will adjust the carb. for you if you ask.
If you can adjust yours, start with one turn out from "seat" and adjust as needed for proper performance.
Feb 12, 2011 | Poulan 25CC Gas BlowerVac
Starts and idles but dies when i pull the throttle.
Either clogged or needs cleaning/ rebuild. ITS SIMPLE! ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jul 06, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Require high and low carb settings for Poulan 2050 with WT 324 carb. It has no primer, so have bypassed primer and run lines direct. Has heaps of spark but will not fire.
May 09, 2009 | Poulan Garden
Adjust high low screws on carb.
Mar 27, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Carbourater for a tecumseh engine
start by closing jets (clockwise). Then turn jets 1 full turn counterclockwise. this should get engine started. Then adjust jets left or right to fine tune,until engine starts running smoothly.
Aug 06, 2008 | Grilling
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
