Question about Intel Motherboard
K8T Neo-V I cannot find user manual form this motherboard, could you help me ? Thanx Fred
  • hydrouest
    hydrouest Oct 23, 2008
    hello all
    I need this manual to be able to rebuild a computer for my daughter or to be sold at low price....
    thans for your hot cooperation
    Fred
  • 59 Answers
Http://www.msicomputer.com/product/p_spec.asp?model=K8T_Neo-V
has all info for this board including drivers
Posted on Oct 24, 2008
Necesito manual de instalacion de k8t neo-v
Follow this link;
http://www.msi.com/product/mb/K8T-Neo-FSR--FIS2R.html#/?div=Manual
Oct 01, 2012 | MSI K8T Neo-V Motherboard
Msi-k8t-neo motherboard ms-6702 user manual
Thank you for the connection.Please visit the following website and download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Regards,Avishek
Sep 28, 2011 | MSI K8T Neo-FSR Motherboard
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
Intel motherboard how to find power switch,led,reset,hdd switch,led
It is silkscreened on the moterboard at the bank of pins for the switches and lights. it is usuall abreviated as PWR SW, RST SW, HD LED, SPKR, PWR LED, ...If it is not silkscreened then look at the manual on the manufactures website. they will have a photo of the MB with it illistrated. go to
http://www.retrevo.com/support/MSI-K8T-Neo-FSR-manual/id/8353ci976/t/2/
Apr 22, 2010 | MSI K8T Neo-FSR Motherboard
Looking to plug in my main switch and need help with finding the right port(s)...only see one color coded set of pins available....
Open the link provided below by MSI;
Download and install Adobe reader to view manual.
Adobe Free; http://www.adobe.com/products/reader/
Manual for K8T Neo-FSR;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo-FSR
Download the maual if needed. Open to page 2-20.
Use the manual to connect you're case wires to the motherboard. JFP1 provides power to Reset Switch, HDD, Power on switch and Power LED. Use JFP2 - connect internal speaker. (Bios uses this for POST).
Power On Self Test. If you use Adobe you can zoom in on pg. 2-20 which will help you connect each set of wires to their matching MB pins.
Cheers'
Mike
Feb 18, 2010 | MSI K8T Neo-FSR Motherboard
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
Msi motherboard for model k8t neo ms 6702
Its the model numbers that vary the most when looking for the manual. Click on the link below to open MSI download site;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+NEO&table=download
While on MSI's site I searched for MS-6702 and left out the term, "K8T NEO". MSI provided the another link; http://www.msi.com/index.php?func=searchresult&keywords=MS-6702&table=download
The model numbers K8T Neo-FSR and FIS2R, use the same manual.
See link; http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565
K8T Neo2-F and FIR use the same manual.
From the pic included, Connect everything to JFP1. Connect the speaker to JFP2.
b972b2a.jpg Wire colors do vary from case to case. Normally solid colors like red, green, blue and dark blue are used as positive. White and black are negative. Each jumper pair will share a common color. That common color is negative except when hooking up the speaker wire. Black is used for negative.
Cheers!
Mike
Oct 24, 2009 | Computers & Internet
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
K8T Neo ,m/board
Thanks to those who responded, . I eventually found the correct place on the MSI Global web site and downloaded the correct manual for the K8T Neo motherboard. Simple when you know how, erm ... and where. Thanks again,
Apr 28, 2008 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
