Question about Protron PDV-228 Portable DVD Player
Dark screen the screen is to dark to see the picture only shodows
  • 10 more comments
  • jafar21 Nov 11, 2007
    Brand new unit out of box. Only finds 13 channels on tuner, and picture barely has color and very dark.
  • Anonymous Dec 12, 2007
    Screen is very dark, can only see shadows. Tried to brighten the color, as well as use with the AC charger but still dark.
  • roger12345 Jan 05, 2008
    I played with the parental control in the remote control, and now i dont see any video, bu the audio plays
    mahdi
  • chandybing Feb 11, 2008
    The screen is to dark to see picture - sound works, but there is no picture. This happened once before and we adjusted the brightness, however, this time we can barely see the bar at the bottom to fix it. Not sure if there is another method we could do to fix it.
  • Anonymous Feb 22, 2008
    I only have sound
  • woodie wood Mar 21, 2008
    SCREEN IS TO DARK, CAN ONLY SEE SHASOWS. SOMEONE MENTIONED CHANGING JUNGLE CHIP. HOW DO YOU DO THAT?
  • territo Apr 01, 2008
    we were watching a movie and the screen went dark. Audio is fine. The unit has not been played a lot!
  • Anonymous May 22, 2008
    brightset high
  • 24348 May 29, 2008
    only blurred picture is seen themode and up down controls are ineffective.seems product is useless
  • Anonymous Aug 18, 2008
    the screen is dark and i can barely see the images on it. does anyone know how to fix this?
  • Anonymous Aug 27, 2008
    the screen lights up for a couple of seconds, then goes out, just barely see a shadow. i tore it apart and found a small circuit board next to the screen. when i play around with the coil, it smokes and i can make it light up, longer or less depending on what i touch. can i get the circuit board and how much? enr@xcountry.tv
  • blueocean016 Feb 24, 2009
    My computer backlight is dark...I dont know what to do with it..I dont have any idea when its about computers...Is there any way i could possibly control the backlight system?? I already maximize its brightness pressing Fn + arrow up thing..No change~~Please help...
Answer
The jungle chip is the main IC processor. It is very complicated and has hundreds of circuits surrounding its complexity. The jungle chip has over 1 million transistors inside and it performs dozens of important functions.
The testing of the horizontal sweep function requires technical knowledge of how the circuits work and interact with each other. There are over 100 components that will need to be tested or looked at. A voltmeter and oscilloscope are necessary to signal trace the horizontal signals from the pedestal strip from the IF to the jungle chip and out to the horizontal sweep and synchronization circuits.
If you go to:
http://www.schematicsforfree.com/archive/dir/Sony/Video
and scan down you will find a service manual download for a model Sony KV32FV15.zip. It is a huge file and will take long time to download, but it contains schematics, parts list and so on. This model is similar to your model and close enough for general troubleshooting. If you have technical skills in circuitry and schematic interpretation it may be useful for you. At least you can get the part numbers for the jungle chip and the horizontal sweep area.
Also, if you go to this web page, it will give you a little more information on the 6 blink diagnostics - again, they are for another model set, but close enough for general guidance on all Sony models:
http://www.iwaynet.net/~nesda/SonyBlink.html
Hope this helps get you started.
Cleggsan
PS: For general guidance and tutorial lecture, go to:
http://www.repairfaq.org/sam/tvfaq.htm
Posted on Apr 03, 2008
    President:
  • 3,130 Answers
The backlight circuit is defective most likly. Its not a consmer repairable thing as there are no user serviceable parts inside these units . Call the manufactuer thats listed in your instruction or owbers manual as they may have an exchange or repir program for these units. Good Luck
Posted on Aug 07, 2006
How old is your equipment? however the problem lies in the video amplifier,luminance has failed. you may replace the jungle chip(i.c.)
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
Black shodows on screen. Visible w/ every source...less visible with bright background...very visible with medium to dark blue background. Have seen a lot of complaints on the Internet related to this...
This problems only two posibilities,one some how u got a light image burn in into the LCD screen panel itself.If it is the LCD screen burn in,this is not repairable.The other one it could be the T-Con decoders board problems and it dying this board sit wright at middle at the bottom of the LCD screen panel to decodes and regulate pictures as it passing and go in and out of the LCD screen panel itself.Tries websites like Shopjimmmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement,possibilites could solved ur light background shadows problems.
Dec 07, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
I have some dark shadow on the right side of the TV screen, I think it could be the lamp, is that true?
No,colors misalignment,shodows pictures and 3D pictures are not cause by the projection lamp.It cause by the tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.The shop will cost u $300-350 for the parts and labors.
Jul 07, 2010 | Zenith D52WLCD 52" Rear Projection...
I have a shadow that covers most of the screen. It
good day. theres a defect in your tv .maybe in the main board. you need a qualified technician to fix your problem.
Jun 21, 2010 | Televison & Video
3 colours shodowing each other
Thats easiallt repaired by installing the repair kit called. The ITC222 and ITC222A convergence option misssing repair kit from www.tvrepairworld.com the kit also contains instructions on CD.
Apr 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black vertical bands in screen. Started as faint shodows now dark
Replace the ribbin cables that connects to the lcd panel. don't have part #
Jun 10, 2009 | Sylvania 6626LG 26 in. LCD Television
CRT monitor's background colour is changed to dull yellow colour
hello,
i think this problem accure due to chage of CRT CATHODE. if you are not a hardware engineer then check it from hardware engineer. any crt monotor have 3 RGB Cathode to release electron on screen. the electron comes shodow mask and create a pixel on the screen the pixel make a picture. The RGB color make the perfect picture. if your picture is dull then i think that happen due to less negative chage of Cathode or any Crt base Bios ic is failior. so you have to checked it from hardware engineer.
ok
bye
Oct 22, 2008 | Samsung 21" FLAT CRT COLOR MONITOR
Dark screen
you may need either a new lcd, or a motherboard, or both..lcd is usually the first issue to resolve..does it work , by chance with an external monitor?
check your computer warranty here 4 FREE
Feb 29, 2008 | Sony VAIO PCG-K23 Notebook
Protron PDV-228 Portable DVD Player Logo
597 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
