Question about Brother SE-270D Computerized Sewing Machine
Sewing machine when trying to sew it says to check upper thread and rethread
  • Brother Master
  • 7,365 Answers
Rethread the machine & see if the thread is caught anywhere
if that doen't help turn the machine off for a few seconds & the turn it back on to see if that will clear it.
Posted on Feb 11, 2012
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Posted on Mar 31, 2009
  • 22 Answers
SOURCE: How to thread bicor vx 1005 sewing machine?
Most older machines start the thread from the spool on a spool holder then the thread goes through a tension dial, on to another tension holder inside the case. Then make sure the thread is going through a lever that goes up and down with the needle, through a thread holder near the needle.
Posted on Nov 10, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
Apr 03, 2016 | Sewing Machines
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
Thread error message
rethread needle using every thread guide, also try changing the needle, if that doesn't help them the machine may have a computer problem
Dec 24, 2015 | Brother SE-270D Computerized Sewing...
Brother pacesetter ULT2003D
try using a different spool of thead on the top and bobbin
and if these suggestions don't help then call the repair shop and check
with them about the machine not sewing light fabric
Jan 04, 2013 | Brother PE770 Computerized Sewing Machine
Machine keeps saying recheck/rethread upper thread
sounds like the computer motherboard could have malfunctioned
and needs to be checked
Nov 21, 2012 | Brother InnovIs 4000D Computerized Sewing...
Upper thread winding around shuttle hook of sewing machine
rethread the needle as the thread has no tension
Aug 30, 2017 | Euro-Pro Sewing Machines
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Cut thread in the middle of sewing.
The tension of the upper therad is too tight. loosen it by following the instr in the manual
or the upper thread is notspinning off the feel freely while sewing. Make sure the upper thread is not getting cought while sewing,
Ot the upper thread is incorrectly threaded, remove the thread and rethread the machine.
Good Luck.
Aug 16, 2009 | Singer 7422
Brother SE-270D Computerized Sewing Machine Logo
90 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
