Question about Intel Motherboard
ASUs P4T533 motherboard diagram - Intel Motherboard
  • 807 Answers
Posted on Feb 10, 2012
Testimonial: "I want to thank Stuart, I was able to locate power switch with his info.Godspeed and thanks again"
  • Greg Blackwell Feb 11, 2012
How to remove grub prompt?
Turn off your computer.
Insert the Windows XP Installation CD that came with your machine.
or borrow one
Turn your computer back on. It will auto-detect the CD.
Type "R" to load the Recovery Console when prompted.
When you see a cursor flashing, type "fixmbr" (no quotes). Press "Enter."
Type "exit" (no quotes). Press "Enter."
Follow the onscreen instructions to restart your machine.
hope this helps
Oct 02, 2012 | ASUS P4T533 Motherboard
My ASUS P4T533-C won't turn on
This is really a common problem with computers these days. It may be caused by a number of reasons like a faulty charging system, faulty battery or anything burned out on the computer's system board. But in this scenario, i would suggest the following
1. Remove the battery and connect the laptop with the AC adapter only and see if it will respond.
2. Remove the AC and re-connect the battery and try to turn it on
3. If the above two do not work, then consider changing the AC adapter for your laptop. You can try to use a different AC adapter that has the same rating as your laptop's. The problem might be with the Charger.
4. But if all this does'nt work, consider getting a Computer Technician who can open up your computer and check the circuit board, there might be a problem with one of the chips
Mar 01, 2012 | ASUS Computers & Internet
I can't find where to plug in the 2 pin swithch wire to the ASUS P4T533 motherboard. willl someone please help?
If you look at the board with the ram and processor at the top there's 2 rows x 10 pins on the bottom right edge. Reading from left to right the power switch connects to pins 6 and 7 on the bottom row. You might be able to see on this picture.
Feb 10, 2012 | Computers & Internet
Whats wrong please help
Firstly, do you hear any beep sounds when turning it on? If you hear no beep sounds this may indicate faulty RAM memory. Try removing the memory and cleaning the connecting points with anti-static liquid or surgical alcohol. This often cures this kind of fault. If this brings no luck, replace the RAM with one which you know is working and try turning it on again.
Let me know if this solves your problem or not.
Best wishes,
Graemevm
Jan 07, 2012 | ASUS P4T533 Motherboard
Asus P4T533-c motherboard fans hard drive everything turns on and fires up but no picture on monitor tried many video cards everything is set right tried in the case out of the case still nothing any ideas
This MB is designed for a 1.5V AGP 2.0 video card. The card slot is keyed to prevent installation of an incompatible board, but there were some older AGP 1.0 cards that use 3.3V that had dual key slots and could be inadvertently installed in the AGP 2.0 slot. If this happens you will damage the MB. Only you can check to see if ths may have been what happened as you say you had tried many Video Cards.
Jan 07, 2012 | ASUS Computers & Internet
Computer was working its a alienware computer with p4t533-c motherboard now it comes on but when you power it on theres usual a beep then it loads but now it wont beep at all and dnt load nothing not even...
toddzr2 - whenever I have a problem like this, you need to unplug all your peripherals, i.e. take out your video card, unplug your hard drive, CD/DVD, etc. Power up, you should get some beeping b/c the video card is out. Power down, reinsert your video card, power back up. See if you can get to your BIOS screen. It's possible that something may have shorted out, i.e. video card, or other peripheral. Don't be afraid to remove the memory as well but make sure you're touching the case to keep yourself grounded and minimize any static discharges.
Aug 13, 2011 | ASUS P4T533 Motherboard
Need manual for a d33007 m/b
Here is what I found on Web? Good Luck :0)
http://www.user-guides.co.uk/download/diagram/diagramd33007/diagram-d33007-motherboard.html
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English Additional information on your ASUS Motherboards MainBoards. This manual has not been listed as either a service or user manual for your 1394 but may be of interest. 2 ASUS P3B 1394 4 ASUS P3B 1394 5 SOFTWARE SETUP 63 6 ASUS P3B 1394 6 SOFTWARE REFERENCE 7 APPENDIX 93 94 Part De ..... diagram d33007 motherboard ... lots more information here
Download And CD Available
Nov 11, 2009 | Computers & Internet
Intel Motherboard Logo
195 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
