Front loading washer bangs and thumps during spin cycle
Doesn't matter if it is a large or small load. Have to rearrange load several times during spin cycle.
Did trouble shooting by running rinse and spin with no load and it ran normally.
Washer is level.
HOW DO I GET IT TO RUN PROPERLY WITHOUT AUTOMATICALLY UNBALANCING THE LOAD ALL THE TIME?
  • 1 more comment
  • dmkushner Oct 27, 2008
    The problem landed up being that the four shipping spacers that hold the shipping screws were not removed.
    The problem landed up being four plastic spacers that the shippng bolts were attached to that were not removed.
  • kscrivens Feb 20, 2009
    I have removed the front of my washer, looked at the shocks that are on it... all four clips are broken off.. now to find them and replace them...
    thank you all for your posts.
  • 566 Answers
Hi may i suggest you remove the top cover of machine and check the drum mountings(rubber) and the spring/s that are connected to the bracket on drum have not broken /come off just one other thing ? when machine was installed was the bracket under the top cover removed b4 connecting and using machine ? this bracket is for security/stability of drum whilst being transported see instruction book ? it is not the first time iv'e encountered this bracket not being removed by customer diy installation worth checking? best wishes
Posted on Oct 23, 2008
I have a LG WM1814CW front load washer. I get UE when it trys to go on spin cycle. I re-arranged the load and still comes up UE. I also tried a cycle without anything in the washer and still the same...
The UE error code is nothing to worry about. It indicates an "unbalanced error"¬-your washer's way of saying that the drum is not spinning is a smooth rotation. It could be as simple as rearranging the load in the drum (click image for zoom). Here's why:
1) Small loads. Your washer operates better when the weight of the load is evenly distributed across the drum, but that is not always possible with small loads.
2) Mixed fabric loads. For example, if you're washing jeans and t-shirts, the jeans could be on one side and the t-shirts on the other, causing the unbalance. Try rearranging the items and spin again.
3) Large single items. Items like sheets, blankets and comforters tend not to spread out evenly, causing unbalance when the drum spins. Rearrange the item and start the spin cycle over.
4) Spin Sense Option. If your washer has the Spin Sense Option, it may try to adjust the load on its own. If that happens, the washer would slow down and tumble a few times slowly during the spin cycle and then speed up until the problem is resolved.
Hope this helps.
Jun 24, 2011 | LG WM-2077C Front Load Washer
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Thumping sound when the water turns on or off? during a normal cold cycle, we especially hear it during the spin cycle. It's not the spinning action it's the water turning on or off that makes a pretty...
Sounds like you are experiencing "water hammering". When the water valve shuts off quickly, the water which was flowing in the pipe must stop, and the momentum of the water suddenly stopping can cause the pipes to rattle or bang. Adding an air chamber would cusion that, and eliminate the banging. I have seen some (at a local Home Depot) which can screw onto the hose right where it connects to the hosehold shut off valve behind the washer.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging noise during spin cycle of my front loading kenmore
If you spin the drum by hand, does it make any kind of thumping or banging noise? If it does, then you probally have a broken spider arm(s). This is very expensive to repair, unless you are handy, it may not be worth fixing. The link below shows the problem and how it can be fixed.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Dec 23, 2009 | Kenmore Washing Machines
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
262 people viewed this question
Top Washing Machines Experts
