Question about Frigidaire FSG748GF Dryer
Frigidaire dryer flxe52rbs8
Dryer takes a long time to dry clothes.
  • 159 Answers
SOURCE: Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Posted on Jul 13, 2007
aborcass
  • 2651 Answers
SOURCE: Moisture in dryer
you have a clogged vent, somehow your vent has become clogged either with in the hose, or where it exits the house, the moisture being removed from the wet clothes is not leaving the unit. CHECK YOUR VENTING POTENTIAL FIRE HAZARD!!!!!
Posted on Oct 26, 2008
futureloginn
  • 734 Answers
SOURCE: Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Dec 02, 2008
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
hunter19_46m
  • 7482 Answers
SOURCE: Frigidaire FEQ1442ES Electric Dryer not producing
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Posted on Oct 10, 2010
Need belt diagram for frigidaire dryer model flxe52rbs8
Hi huntmi04...
Go to the follwing webpage and see a picture of how to route your belt
Please take time to rate
http://www.expertappliance.com/dryerbeltconfiguration.html
Sep 06, 2011 | Frigidaire Dryers
Clothes take.2 hours or more to dry
Check to make sure that the dryer vent is clean. Most of the time when the clothes take a long time to dry it is the vent. If the vent is clogged then it cannot circulate the air inside the dryer. Also check underneath the lint filter to make sure it is not clogged as well
Jul 12, 2011 | Frigidaire FEX831CS Top Load Stacked...
Dryer takes twice as long as it used to to dry clothes, any suggestions?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 30, 2010 | Frigidaire Electric Dryer
Spinning and hot butnot drying clothes
If your
Dryer Maintenance
heatman101
Dec 18, 2010 | Frigidaire FEQ1442ES Electric Dryer
My dryer takes a long time to dry, what could this be?
Normally when a dryer is getting hot but taking too long to dry it indicates that it either has a clogged vent or poor air flow. You can check this by turning the dryer on and then going to where it vents out of the house and see if there is a strong air flow, or by taking the vent off the back of the dryer and letting it run and see if the clothes dry in one cycle. 99% of the time its going to be some sort air flow problem.
Dec 09, 2010 | Frigidaire GLER341A Electric Dryer
Dryer heats up but takes forever to dry clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 13, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Front Load Dryer Model # leq2152eeo Problem: it is not drying the clothes. The dryer heats up and everything else is working, except it takes 4 cycles to dry something that should have dried...
while the dryer is running.go to the outside of the house and check the air flow,there should be a large amount air being blown out if there is not check the vent and ducting for lint build up and make sure the hose is not kinked.
when there is restricted air flow all the warm moist air will stay in side the dryer causing the clothes to take a long time to dry. i hope this helps you with your dryer
Jan 24, 2010 | Dryers
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
No heat - long time to dry clothes.
Hi, Is this an electric dryer? The model# shows that is it. If it is gas, you need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $27.95. Our # is 1 866 798-4375 Make sure and check the venting to the ouside and make sre that it is clean and has no kinks.
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Dryers Logo
90 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
