Question about JVC AV-27230 27" TV
Tv on with sound but no picture
When turning on TV, there were no pictures (screen is dark) but only sound (audio ok) coming out. What kind of vedio problem is this? Please help.
  • run zhou Aug 07, 2006
    please help.
My jvc tv has sound but no picture. Sometimes when I turn it off for a few minutes it has picture then it goes black
Posted on Nov 07, 2011
I light when it comes to tv repairs but I used to do this few years ago. What electronics components that usually get affected causing this to happen? At the DEFLECTION section I measured AC for 12VAC to 12Vac but at 26VAC I got 49Vac, what could be the problem? Please help may be I can manage to revive the this tv.
Posted on Oct 11, 2012
    New Friend:
  • 163 Answers
One that you cant handlel, many of the conponent of the tv can cause this problem, from the power supply to the picture tube but at this point regular people cant check anything in a tv, get a tech and pray to get a good one, beacouse the price of the repair ...good luck
Posted on Aug 07, 2006
Toshiba model CF30D50 has sound and will change channels, but picture is dark, can see vedio 1 and 2 faintly, but can get no picture on TV channels
Its a older set with 3 picture tubes---when was the last time the mirror and three lens for the tubes were cleaned?
Dec 13, 2012 | Toshiba Televison & Video
Sound but no picture
Hello!
Does sound comes out of TV speakers? Or you have "home theater" hooked up to?
In first occasion: TV turns on, stays on, display blinks once, then nothing?
Inverter is at fault. Second occasion: TV turns on, stays on, display glows dark, sound OK, no picture: T-con board at fault. Third occasion: TV turns on, shuts off, sound is coming through "home theater"-OK. Power supply or inverter, or T-con are at fault. TV need major diagnostics and repair in every case. Let me know if you can handle that. Will guide you through the process.
Thanks,
Alex.
Dec 15, 2011 | Toshiba Televison & Video
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Apr 04, 2009 | LG 50PC5D Television
No picture when TV is turned on, sound is OK
try to look at its circuit board and look for cold solder or loose solders usually solders with crack,they might be the problem,i dont think its the flyback coz you have audio.try also look at its picture tube at the back tru the crt if the filament is ok or it may also have loose connections
Jan 13, 2009 | Samsung TXJ2554 TV
T.V. went off during thunder strom- now nothing(no audio/vedio only clicking.
IN WICH STATE ARE YOU? IF YOU ARE IN MD-DC-VA WE CAN GO THERE AND TRY TO FIX IT
CAYPIANAN@YAHOO.COM
Oct 22, 2008 | RCA Scenium M50WH187 50" HDTV
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My picture went dark but the audio is ok on Philips model 51pw9303
your tv needs to be taken to tech i is having problem in the video and related circuit.or power supply.good luck
Apr 03, 2007 | Philips 51PW9303 51" Rear Projection...
JVC AV-27230 27" TV Logo
588 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
