Question about GE Refrigerators
GE Fridge water dispenser working but not the ice
GE side by side stainless steel fridge is dispensing water but I haven't heard the icemaker working. Is there a trick that I am missing here?
  • GE Master
  • 4,654 Answers
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Posted on Feb 10, 2012
    SOURCE: water dispenser in fridge
    Possible problems could a bad water valve (dual valve), bad micro switch which is activated by pressing the button for water to come out. On some models the bracket that holds the micro switch could be broken not allowing the button to activate.
    Posted on Oct 05, 2007
    • 23 Answers
    SOURCE: GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
    Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
    Posted on Dec 07, 2007
    • 6 Answers
    SOURCE: Amana Side by side refridgerator Model SBD20TPE P1190006WE
    hi
    one question : are the units under warranty ?
    if not its pretty easy to swap the dispenser paddles and the membranes
    infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
    thanks
    Posted on Jun 05, 2008
    • 72 Answers
    SOURCE: Maytag side by side fridge...water dispenser problem
    If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
    Posted on Jun 15, 2009
    woodchuck789
    • 4070 Answers
    SOURCE: water dispenser is not working
    You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
    Posted on Oct 05, 2009
    Ge fridge is not making ice at all
    Make sure the wire arm is in the down position. If it is in the up position this signals the icemaker that the bin is full and icemaker shutsn off. Hope this helps.
    Dec 31, 2013 | GE Profile PSW26P Stainless Steel Side by...
    Not getting any water out of the dispenser, but its making ice
    The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
    Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
    GE PSS26GRE SS not dispensing ice
    The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
    If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
    Thank you for contacting Fixya.com
    Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Ge fridge makes Ice, doesn't dispense
    turn freezer side to zero for 1 minute. press water dispenser
    Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
    I have a GE side by side stainless steel refrig. the water will not dispense. How can I fix it?
    Is there water to the water valve in the rear of the fridge? If yes, replace the water filter if older than 6 months or if you're on a well. You may need an inline water filter behind your fridge in addition to the one in the fridge to protect the water valve. If no, turn on the water. If you're making ice but no water dispense and you have a new water filter. Replace the water valve.
    Dec 10, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
    Ice/water maker won't dispense
    Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
    Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
    Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
    Refrigerators Logo
    229 people viewed this question
    Top Refrigerators Experts
    Sal De GO PATS
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
