Question about LG Dryers
I have DLE2050W dryer and doesen't heat up or dry what can be the problem
3 Suggested Answers
canwoodjc
  • 3301 Answers
SOURCE: My Lg Dryer Model #
your machine has thermostats Your dryer uses multiple thermostats to regulate its internal temperature. The cycle selected determines which thermostat is used. A cycling thermostat can be found somewhere in the path of air that is leaving the drum. It could be found on the blower wheel housing or inside the venting/exhaust system. Dryer thermostats are usually oval shaped and about an inch and a half in length. Also, there should be two wires leading to each thermostat. Label these wires before you remove them so that you are able to correctly reconnect them later.Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. If your not familiar with this, consult a repairman
Posted on Jul 04, 2011
hunter19_46m
  • 7482 Answers
SOURCE: my dryer runs and heats
Hi mandolins23...
Sounds like your venting system is plugging up, try these suggestions below...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Posted on Aug 30, 2011
DLE2050W
Hi Ron Arsenault
Sounds like your timer is faulty and not allowing the dryer to shut off...replace your timer, they are not re-buildable
Go to the following webpage for parts.
Note: Try to replace the timer with the same mfg,..and replace only one wire at a time to keep from getting confused.
Bud
http://www.appliancepartspros.com/search.aspx?model=dle2050w
Oct 09, 2012 | LG DLE2050 Dryer
My dryer isn't drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 22, 2011 | KitchenAid Dryers
Hiow old is my Kenmore Dryer 110 62952 100 It has heat; starts to dry; then stops. Sometimes it finishes drying a load and sometimes not.
heatman101';
Jul 16, 2011 | Kenmore 62802 Electric Dryer
My Lg Dryer Model # DLE2050W turns on but doesn't heat up and I was tryig to find out if it was because of the heating element or if it has a thermal fuse and can that cause it not to heat. If so...
Jul 04, 2011 | Dryers
My dryer only damp dries. Cannot dry towels. seems to take forever to dry anything
Hello there and thank you for choosing fixya
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jun 29, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
WON'T DRY CLOTHS..NO HOT AIR
heatman101;'';';
Jun 27, 2011 | GE Dryers
The dryer does not heat. All electrical circuits have been tested and there is power to the dryer on both legs of the power cord. The cool down light stays on with the sensor dry and timed dry settings and...
heatman101
May 21, 2011 | LG DLE2050 Dryer
My drying is not sending hot heat to dry the clothing what should i do
heatman101
Apr 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
26 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
