Question about Brother Office Equipment & Supplies
Is there a way to set up the brother 8440 to a digital phone line?
    Genius:
  • 2,120 Answers
No, ALL fax machines are ANALOG devices. It may work for a couple of faxes, but it will be very unreliable.
Posted on Oct 23, 2008
MACHINE ERROR CODE 6B ON BROTHER MFC-8440 ?
A6 error means the CIS unit is defective and needs to be replaced.
Unfortunately this can sometimes cost more to replace then the machine itself
Thank you
Regards,
Suhail
May 16, 2012 | Brother MFC-8440 All-In-One Laser Printer
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Jan 26, 2010 | Brother MFC-8440 All-In-One Laser Printer
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
Two fax machines on one line, one won't send
Buy a double outlet RJ-11 adapter.
Set the one you use for sending only to MANUAL RECEIVE.
Jun 22, 2009 | Brother MFC 8440 All-In-One Laser Printer
Brother MFC-8440, send fax ok, but no receiving fax
The manual has step by step instructions, I'll include a link for the online version. Section four runs through setting up recieving, if it's on a dedicated line follow the first set of instructions to set up automated answering. If it's a shared line(phone/fax) then continue down to the next section.
Note: for a shared line you may need to contact your line provider for a second number that has a "dedicated ring"
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf
Hope this helps FixYa,
Chris
Apr 11, 2009 | Brother MFC 420CN All-In-One InkJet...
I have a brother mfc-8440
I would try to plug a regular phone in the jack to see if you are getting a clear signal/dial tone to the machine, if not, you may need to have the phone company come check it out.
Nov 18, 2008 | Brother MFC-8440 All-In-One Laser Printer
Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Aug 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother 8440
ONLY FROM A AUTHORIZED BROTHER SERVICE CENTER. ABOUT 59.00 - BROTHER TECH
May 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
23 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
