Question about New Home Sewing Machines
Reverse broken new home SL 2022
It no longer reverses.
4 Suggested Answers
  • 718 Answers
SOURCE: Broken Cam
You can try;
http://www.a1sewingmachine.com/parts.html
Email your parts request to them.
Or you can contact your local dealer.
You can get an owner's manual from;
http://www.riccar.com/help/manuals
Posted on Mar 28, 2009
  • 980 Answers
SOURCE: new home SR 2100 sewing in reverse when it should sew
You need to take the machine in for adjustment, on that model you cannot do it yourself
Posted on Jun 27, 2010
  • 1456 Answers
SOURCE: I have an sx 2122
Hello
I'm thinking it's that you have to hold it down the whole time you want to stitch in reverse,if not,
The most common cause of machine misbehavior is - believe it or not - the needle. So swap it out. I don't care if it is brand new --- sometimes they are bad from the manufacturer. It is such a simple fix and one that you need to learn right now -- when in doubt -- change it out!
Be sure to install the needle the right way. There is a flat side that needs to hit the adjusting screw so that it doesn't wiggle around when sewing.
Next - be sure that you have threaded the machine correctly - go back and look at the owner's manual and re-thread the machine -- leaving about a 2-3" tail after going through the eye of the needle from front to back.
Now - for the bobbin -- is this the bobbin that came with the machine? If you purchased new ones - are they the right size - it doesn't go well with the wrong size bobbin. OK - now, did you wind it on the machine or by hand? If you did it by hand -- is it evenly, tightly wound. Are you using standard thread or are you trying a specialty thread?
Did you put it into the bobbin case / holder going the right direction -- machines can get pretty finicky - so make sure that it is unwinding the correct direction. It must turn counterclockwise. If the bobbin is in backwards or upside down - easy to do on some machines, and impossible on newer models, it can cause a great deal of trouble.
Also, make sure that you have not inadvertently bumped the tension adjuster for the bobbin. This can be a stick like adjustment at the top of the machine - may be an adjustment on an LCD screen - it varies depending on the model.
Again leave a 2 - 3" tail and put it in place correctly.
Make sure that the presser foot is up - and that the feed dogs are engaged.
Now - using the hand wheel on the right side of the machine - and holding on to the upper thread tightly - move the needle up and down once to bring up the bobbin thread through the throat plate of the machine. The bobbin thread will be caught up and a loop will be visible between the presser foot and the base plate. Gently pull both threads up and to the back of the machine - out of the way of your sewing.
When you begin working on a piece of material - hold both threads firmly to the back and take the first few stitches slowly to make sure that they are not going back down the throat of the machine. Be sure NOT to try to start at the very edge -- begin about a 1/8 to 1/4" in from the edge. If you are doing quilt work and only using a 1/4" seam - then back up after starting and come forward again. If you are using a traditional 5/8" seam allowance - no worries
Posted on Aug 02, 2011
Need an operator manual for a New Home Sewing machine Model SL-2022
You can purchase a manual for the SL-2022 from Sew USA: http://www.sewusa.com/Sewing_Machine_Manuals/New_Home_Manuals/New_Home_2022_Instruction_Manual.htm or from Sew4Less: http://www.sew4less.com/product/561/New_Home_SL2022_Instruction_Manual . Since Janome no longer has the manual for this machine, you can't download it from their retired machine's manual page.
I hope this helps.
(Janome owns the New Home brand name.)
Mar 25, 2016 | New Home Sewing Machines
My new home HF l5024 sewing machine won't go in reverse how can I fix this ??
the gear that controls the reverse could be damaged or broken, may need to be checked
Jan 24, 2016 | New Home Sewing Machines
Janome model us 2022
here are 3 links for a janome 2022 for any other part you'll have to contact a janome dealer or check ebay
Janome 2022 Parts Janome DX2022 Parts Janome HF2022 Parts
May 01, 2014 | New Home Sewing Machines
Reverse stitching not working
have the machine checked, to see if the part that works the reverse is broken.
Mar 20, 2014 | New Home MX-3123 Computerized Sewing...
My machine will not reverse stitch. What can I do?
when you try the reverse stitch lever or knob and it doesn't respond then the machine needs to be checked to see if there is a broken part.
New home SR 2100 sewing in reverse when it should sew
Jun 26, 2010 | Sewing Machines
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
I need a manual for my new home model 2022.
You should be able to get one from your Janome dealer. If you can't, I can get one for you.
Aug 04, 2009 | New Home HF-2022
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
