Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Refrigerator warm, freezer very cold. after defrosting, will work for 4 days
Kenmore bottom freezer refrigerator. model 596.6523 about 3 years old. Freezer door was open aprox. 2 inches overnight. Lots of frost in freezer & refridge stopped cooling. Found coils frosted over & thawed. worked good for 2 days. shut off power for about 16 hrs. worked good for 4 days. now refridge is warm, lots of frost in freezer & it appears that the coils in freezer are iced over again.
What should I look for?
bobotfel
  • 236 Answers
SOURCE: kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
Posted on Jan 11, 2008
  • 87 Answers
SOURCE: Fridge warm, freezer is cold
First off all i type so fast that my spelling is junk! so bear with me. now most tec's will recomend that you defrost the unit. uhh uhhh . the fact of the mater is you have air in the lines they hope that the air due to defrost will settle to the bottom, well we both know that air always goes where! lol to the top. lol. this is crazy but this is somthing they dont want you to know . see when you take the unit in to get repiared they (a corse when you leave) will flipp the unit up side down fore about 30 min to get those air molicles to te top . then quickly flipping it back up plugging it in just to get the compresser to kick in thuss leving the air at the bottom . doing this properly and susksefly will fix the problem. see when this unit was made was upside down. lol. you dident know this right. well every 100 unit is tested . lol they have to flip it up right when it passes the test. so what do they do . flip it back down. lol . before it leaves the back door its flipped back up agin.lol . to make a long story short you have one of those 100 units lol. its ok i just armed you with the key to the lock.
Posted on Jul 14, 2008
huuum
  • 750 Answers
SOURCE: I have a zanussi fridge
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Posted on Oct 05, 2008
abhishek33
  • 1239 Answers
SOURCE: Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Posted on Nov 06, 2008
godtech
  • 51 Answers
SOURCE: Freezer building up lots of frost, but on lowest setting.
FREEZERS SHOULD BE TEMP AT O /REFRIGERATOR SHOULD BE 40/FOR PERFECT OPERATION.1ST IS THE FAN RUNNING IN THE FREEZER/IF YES UNPLUG FOR 6-8 HOURS AND RETRY/IF NO UNPLUG THE FRIDGE AND REMOVE THE BACK PANEL OF THE FREEZER MAKE SURE THE FAN IS PLUGGED IN.IF SO PLUG IN THE FRIDGE AND SEE IF THE FAN IS TURNING.IF NOT YOU NEED A NEW FAN IF THE FRIDGE IS NEW MAKE THEM BRING YOU A REPLACEMENT FOR FREE.
Posted on Jan 17, 2009
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
I own a Kenmore Coldspot 106.71182101 and the refrigerator is now warm while the freezer is perfectly cold and holding it's temp. What can I do about the refrigeratornot being cold?
A common problem; the fan which should circulate some of the cooled air into the fridge is not running. You can verify this while the compressor is running by wetting your fingers and holding them near the vents in the back of the refrigerator. If you cannot detect any air flow, the fan is dead.
Go to Sears parts website and enter your model number. Especially since it is Kenmore, it should bring up a line-drawing and parts list for your model.
Sears Parts Direct
You can then decide whether it is accessible enough for a DIY replacement or if you would rather call a service company to replace it for you. Check with your local BBB to pick a reliable service company.
Aug 04, 2010 | Refrigerators
Temperature is not cold enough?
Model #106.8678213, The complaint was the refrigerator section was getting warm while the freezer seemed OK. The unit had been unplugged for a couple days and when I turned the unit back on, the cooling system worked fine, but I did notice a lot of water in the condensate tray which lead me to a possible defrost problem. Removed the access panel to the defrost timer and found the timer motor was not running. So basically what happened was the unit stopped defrosting and eventually built up enough frost and ice on the evaporator to block the airflow to the refrigerator section. Once the power was removed, the unit defrosted by itself and left the water in the tray. I replaced the defrost timer so now it will defrost every 8 hours like it was designed to. Now get back with me and see if the model number located on bottom kick plate it should be a number that Sears only uses. They use model numbers like this on everything and every brand. looks again like this sample ( 106.8678213 ) hope this helps, Sea Breeze
Apr 12, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
61 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
