Question about Intel Motherboard
MSI MOTHERBOARD 865 PE WILL NOT POWER UP. JUMPER PINS MAY BE IN WRONG LOCATION
  • Intel Master
  • 27,725 Answers
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might be getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Posted on Feb 11, 2012
map9966
  • 2351 Answers
SOURCE: MSI Slot 1 MS-6111 Motherboard
Click the link below which will take you a site that has a black & white shot & description of the board, Slot 1 MS-6111. It shows everything you need. Scroll down & listed is what goes where.
http://stason.org/TULARC/pc/motherboards/M/MICRO-STAR-INTERNATIONAL-CO-LTD-Pentium-II-MS-6111.html
please vote...
Posted on Feb 13, 2008
kamakani
  • 104 Answers
SOURCE: MSI 945GCM478-L Power SW combination?
http://www.retrevo.com/support/MSI-K8N-Neo4-F-manual/id/8353ci956/t/2/
I hope this helps you.
Posted on Jul 06, 2009
proton77
  • 1183 Answers
SOURCE: reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Posted on Aug 15, 2009
sys_admin
  • 829 Answers
SOURCE: i have an intel 865 pe motherboard and cant figure
Hi , Kindly find the below image .
Posted on Jan 16, 2010
emissionwiz
  • 78267 Answers
SOURCE: is there a master fuse on a MSI 865PE Neo2-V
there are fuse links (they look like little pieces of wire) they are marked as such on the motherboard.
Posted on May 27, 2010
Motherboard msi 7610 ver 2.1
To reset the motherboard: set the dipswitches at OC_SW1 to ON-OFF-ON, then clear the CMOS Ram by setting the jumper at JBAT1 to pins 2&3 while the power is OFF. Wait fifeteen seconds,Then return the jumper to pins 1&2 and turn the power on. This will re-set you to the factory defaults. You will need to enter the BIOS and re-configure your hard disk. The manual can be downloaded at ECS's website at: http://www.msi.com/product/mb/P41TC31.html#/?div=Manual
Apr 18, 2014 | MSI Ms-7610 P41t-c31 Motherboard Intel G41
I have no on board video or external video via the agp video card. computer emits no beeps during boot prosess. all power supply voltages are available.
I've got a via p4m266. and I've found that it does that if you put the cmos reset jumpers on the reset setting. check for one stand alone jumper across 3-pins, check readings on board for location of cmos reset jumpers & move jumper to bridge the unbridged connection.
Nov 14, 2010 | MSI : P4MAM2-V (7095-010)...
I need to find the bios reset on the motherboard of a msi k8mm-v
The BIOS reset jumper is located next to the lower SATA connector inbetween the front panel connector pins and system fan power riser.
Aug 22, 2010 | MSI K8MM-V Motherboard
Where is jumper reset
The reset jumper is labelled JBAT1 (circled in red below). Pins 1+2 are jumpered/shorted right now, just turn the machine off, move the jumper over to short pins 2+3, wait 5-10 seconds, move it back to pins 1+2 and fire it back up. Have fun!
May 25, 2010 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
How do you get the password off of the
There are two ways to reset the boot or the bios password:
1.By removing the CMOS battery
You have to shut down the computer , disconnect the power plug and open up the unit and locate the CMOS battery ( which usually looks like a coin) . Carefully lift the battery out of its socket and set it aside.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
2. By using the motherboard jumper
Shut down your computer and disconnect the power plug. Identify where the jumpers are located. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. Then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down! Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.
For detailed instructions and snapshots u can check up this link :
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Mar 15, 2010 | Computers & Internet
LITTLE BLACK AND WHITE CABLE HAS BEEN MOVED. IT RUNS FROM THE ON/OFF SWITCH TO THE M/BOARD BUT I KNOW NOT WHERE. cAN YOU HELP PLEASE
Look for jumper labeled JFP1. On this jumper are the following pinouts:
Pins 1&3 = Hard disk drive LED
Pins 2&4 = Power Indicator LED
Pins 6&8 = Power on/off switch
Pins 5&7 = Reset switch
Jan 08, 2010 | MSI P4M900M-L (7255-060(P4M900M-L))...
Usbs not working mobo is the msi 865 pe neo2-v bourd
see to it if the drivers install..if doesn't ,install it..
and go to BIOS SET UP..
see if the USB PORT IS ENABLE or not..
if not, enable it so that you can use it..
Oct 28, 2009 | Intel Motherboard
How do you reset or bypass cmos password on msi wind u100 notebook.
hi this is kamal..
pls follow these steps:
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
best regards
kamal singh
Oct 09, 2009 | Computers & Internet
MS 6378 bios Was crypted. Tell me about password reset! KYBRA
You can to reset password by jumper on motherboard his name CMOS CLEAR or CMOS RESET .
it plased near the 3 volt battery .
It look like 3 pins a 1 jumper on it.
reinstall for 2 second jumper to anover two pins from 2-3 to 1-2 or (from 1-2 to 2-3 ) and password will be cleared !!!
but the over settings will be cleared too.
P.S. if you can't find this jumper just to try remove the battery for 10 minutes and disconnect power cord from power supply unit, but it may be no useful.
Mar 23, 2009 | MSI MS-6378 Motherboard
Intel Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
