Question about Nokia 6600
I forget the lock code and when i start my phone it ask me to enter code
I set a lock code on my phone and i forget my password. when i restart my phone it ask me to fill the lock code and now what should i do because it is not showing the forward screen. again and again shows lock code error if i put something on it.
  • 83 Answers
Ok try following steps:reboot your phone when they getting reboot press = green button(answer key) + 3 star key(*) but befor that make sure that your phone data will be lost above procudere may restore factory settings of your phone
Posted on Oct 25, 2008
I forget my n72 mobiles lock code so how to reset the password agan
After 5 consecutive incorrect password, youll be asked to wait for couple of minutes. After waiting, enter 12345 then it should be your new and current password. From there, you will be able to set new password for your phone.
Dec 06, 2011 | Cell Phones
My cellphone is locked n i can unlocked please help me :{
Its locked to security code or Network Lock,it locked to Network means get the Network UNLOCK CODE from here
theunlockspot.com and Unlock it,It locked to security code means get the default code from service provider and reset it,you can also use the master reset code to reset Phone from security lock and password Lock,get the master reset code for Nokia and Alcatel Mobile Phones there itself and reset from security lock.
Aug 15, 2011 | Cell Phones
How do you set a passcode for a Sony ericsson j108a so that only I can use my phone
You can stop unauthorized use of your J108a phone by activating phone lock protection.
After activating, you will be asked to enter your phone lock code every time you restart the phone.
The default phone lock code is 0000 (zero-zero-zero-zero). It is recommended that you change this to any four-to-eight-digit personal code.
Note: It is important that you remember your new code. If you forget it, you need to take your phone
to your local Sony Ericsson retailer.
To activate the phone lock:
1. Select Menu > Settings > General > PIN codes > Phone protection > Protection.
2. Select 'On' if you want to enter a lock code every time you start the phone, or select 'Automatic' if you want the code to be entered only when the phone restarts after a new SIM card is inserted.
3. Enter the phone lock code (0000 by default) and select OK.
To unlock the phone:
• When 'Phone locked' appears, enter your phone lock code and select OK.
To change the phone lock code:
1. Select Menu > Settings > General > PIN codes > Phone protection > Change code.
2. Enter the old code and select OK.
3. Enter the new code and select OK.
4. Repeat the code and select OK.
This solution was taken from Sony Ericsson J108a user guide which can be downloaded at:
http://www.sonyericsson.com/cws/download/1/835/750/1284993225/J108i-J108a__UG_EN_1241-2576_1.pdf
Mar 12, 2011 | Sony Ericsson Cell Phones
What is the original password for wing mobile???
Tap the "Start" button, followed by "Settings."
Tap "Security" or "Personal tab," followed by "Device Lock" or "Lock."
Enter your existing password when prompted.
Enter the default password in the "Password" box. Refer to your phone's user's manual to retrieve the default code. The most common default codes are "1234," "0000" or the last four digits of your cell phone number.
Re-enter the default password again to confirm your entry, and then create a hint to help you retrieve the password in the future in case you forget it.
Tap the "OK" button to complete the process.
Hard Reset Tap the "Start" button, followed by "Settings." Tap "Security" and click the "System" tab. Locate and click "Clear Storage." Enter the security code when prompted. Tap "OK" to confirm your decision to perform a hard reset. Wait for the phone to restart.
Thanks for rating
Dec 24, 2010 | T-Mobile Wing™ Smartphone
Locked out of my blackberry curve 8520 smartphone
If you are locked out you can enter the wrong password several times and the phone will restore to factory settings. The downside to this is you lose everything unless you used the backberry server and saved!
Mar 02, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do i set password to access my phone (V9)?? I want to set a password on my phone so that no one else could just open it and start fiddling with my personal stuff. I can easilydo that on a nokia but i...
usually your able to go into the menu and the either options or settings and click on security! but some phones are so dang complicated. lol here is what ive found its a razr 2 v9 right?its from the motorola website
codes & passwords
Your phone’s four-digit unlock code is originally set to
1234. The six-digit security code is originally set to
000000. If your service provider didn’t change these
codes, you should change them:
Find it: s >wSettings > Security > New Passwords
You can also change your SIM PIN or call barring
passwords.
If you forget your unlock code: At the Enter Unlock Code
prompt, try entering 1234 or the last four digits of your
phone number. If that doesn’t work, press s and
enter your six-digit security code instead.
If you forget other codes: If you forget your security
code, SIM PIN code, PIN2 code, or call barring
password, contact your service provider.
lock & unlock phone
You can lock your phone to keep others from using it.
To lock or unlock your phone, you need the four-digit
unlock code.
To manually lock your phone: Presss>
wSettings > Security > Phone Lock > Lock Now, then enter
your four-digit unlock code.
To automatically lock your phone whenever you
turn it off: Presss>wSettings > Security > Phone Lock >
Automatic Lock > On, then enter your four-digit unlock
code.
Oct 02, 2009 | Cell Phones
I have forgotten the lock code of my e66. now when i restarted the phone it asks me for lock code. can some one help
Nokia E66 I forgot password. When I restarting asking lock code.
How do I get password
Aug 06, 2009 | Nokia E66 Smartphone
Code
enter a wrong password three to four times.then the cell will ask for the PUC code. your cell phone's book has the PUC code.enter it.then the phone will start working.
Oct 14, 2008 | Nokia 6233 Cellular Phone
Security code forgotten
hello. sir. i have forget my lock code. my cell IMEI no is. 354533011436211. pl send me the master code of this phone.
Apr 02, 2008 | Nokia N73 Cellular Phone
Nokia 6600 Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
