My magnavox hdtv makes snow noise - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Hello
Check its antenna connection for firmness. It should be tight to an extent. If it got loose, the snow [video noise] will be there on picture. If it tight and still there is snow, check for any connection break at the antenna mast over the roof. If all are found OK, and still the problem perists, the tuner to your TV is defective and should be replaced.
Posted on Feb 10, 2012
Why does my magnavox 52 inch dlp make a fairly loud humming noise for 10 minutes or so after turning the tV on? It gradually get quieter.
It is likely a bad fan that gets quiter as it warms up from use. There are two fans on that TV - one under the bulb housing and one at the left vent hole. They are special fans with three leads - +, - and an RPM indicator (yellow lead typically).
Apr 24, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 50 mls105d/17 is making noise
soudns like your color wheel may be going bad or the fan. Fan would be the first to check.
Jan 17, 2013 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Cant get my 14" Craig TV to work anymore.
Check the connection at the back of the TV. During moving, any of them might got loose. Check it. As the TV has snow and hissing sound, there is no fault with it. The fault must be to the cable or antenna connections.
Jun 05, 2012 | Televison & Video
My 50" magnavox 50ml8105d/17 making a knocking
It sounds like you have a bad color wheel. If you are handy with electronics, it is a pretty simple fix. If not, I would suggest you take your set to a qualified service center.
Apr 01, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
2nd time my phillps 50 dlp hdtv has messed up. sound no picture lasts time it was a bulb. doing the same thing this time but making a funny noise this time
The fans & " Colour Wheel " ( inside the optic engine, looks like a multi colour glass disk with a motor attached ) are a problem with most DLP TV's
start there
hope this helps
Sep 22, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
After 2 foot snow and riding on snow packed roads, rumbling noise from under car.
With all due respect, what the H___ are you doing driving in 2 Feet of SNOW? The rumbling noise you hear is most likely caused from Snow being impacted in the CV Joints, Wheel Wells and anywhere else from freezing in place after driving in the "Deep Snow". The solution is to have the care raised on a Hoist and Pressure Washed to remove all Snow and Ice from the the entire Bottom Side of the Vehicle. It then should be allowed to dry thoroughly in that building before being driven. Additionally, if any noises occur upon exiting that facility turn around and have it repaired before it costs you untold thousands of dollars to repair.
Next time you have "DEEP SNOW" wait until the Roads have been cleared, salted or sanded and are back down to pavement before driving on them.
Jan 01, 2010 | 1997 Cadillac DeVille
Hi, I have a Magnavox 17MD255V/17 combo dvd-tv. Everything works fine except that the AC adaptor has a high-pitched whistle that continues while the tv is on. I tried unplugging from the the tv itself and...
TAKE THE AC ADAPTER APART. LOOK AT WHERE THE MANUFACTURER PUT HIS GLUE AND REDO IT CLEAR NIAL POLISH WORKS BETTER IT FLOWS UNDER THE PARTS BETTER. YOU CAN PLUG IT ALL IN WHEN ITS APART BUT MAKE SURE NOTHING CAN SHORT OUT. THIS WAY YOU CAN PINPOINT WHERE THE NOISE IS COMING FROM. OTHERWISE GLUE THE TRANSFORMER AND ANY SMALL FERRITE BEADS THESE SWITCHED MODE POWER SUPPLIES OPERATE AT HIGH FREQUENCIES AND LOOS PARTS CAN VIBRATE CAUSING THIS NOISE.
Dec 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
