Question about Dryers
Wiring diagrams for installing ceiling fans
Wiring from a light switch
  • 3 Answers
There should be a black,white,green and blue wires...tie black and blue together, white is common and green or bare copper wire is your ground.If this does not make any sense, get professional help.
Posted on Feb 10, 2012
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
SOURCE: Installing ceiling fan with two switches AND a remote
I have a hampton bay ceiling fan with light fixture all connected to a wall switch and controled by a remote. The light does not work any more and I have replaced the bulb with three different light bulbs and it still won't work. There is a green wire coming off the bracket but there is no ground wire coming in from above. There are two wires coming in from above ( the box in the Attic)
one white and one black and they are connected properly. All the wires are taged from the remote receiver, the fan and the light and are correctly connected. Any suggestions?
Posted on Mar 30, 2008
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
  • 69 Answers
SOURCE: need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Posted on Sep 23, 2009
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
Hampton Bay fan wiring
this is everything u need to no
'http://www.ceiling-fans-n-more.com/ceiling-fan-wiring.php
it has all the colors and a diagram for you
Sep 29, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Ceiling fan and light not working after short trip.looking for wall switch,gfi,or breaker.no wire ring diagram
Ceiling fan and light Bruce, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Wire Fan Light With Black White Blue Wires
Install or Replace Ceiling Fan
Wiring Diagrams Ceiling Fan and Light Kit
How to Wire Ceiling Fan With Light With Different Switches Ceiling Fan...
Mar 23, 2016 | Dryers
I have a 3 speed fan switch with 4 wires. The wire colors are grey,black,yellow,and brown. Where do they go such as L,1,2,3 on the switch?
Did you get a wiring diagram with the switch/fan? This should tell you which is which.
Each manufacturer has different color coding. If you didn't get a diagram, contact the manufacturer for instructions.
Good luck,
Handie Andie
Mar 25, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
I want to add a bedroom ceiling light to the one aready installed
Probably, meaning ya have Phase Neutral & Earth.. and they are generally wired up to a switch, (one set of wires) and then sorta the In set from the distribution board and the Out set...that goes on to "Other" circuits. The switch nust be wired to "Break" the circuit from distribution board, when activated. Draw a diagram to help.
Jan 24, 2010 | Sea Gull Lighting 1555-734 Three-Light...
Need a basic diagram to wire a ceiling fan.
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Jun 14, 2009 | Cooper Lighting Lighted Switch
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Dryers Logo
82 people viewed this question
Top Dryers Experts
