Question about Vehicle Parts & Accessories
Timing mark adjustment for 2003 ford focus
Dual cam
4 Suggested Answers
  • 1757 Answers
SOURCE: timing marks for 2000 ford focus
Click on the following direct Link.
With the DOHC you will need the Camshaft Sprocket Holding Tool and Camshaft Alignment Tool.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2000/make/ford/model/focus/2000_ford_focus_timing_belt_diagram_marks.htm
Posted on Mar 19, 2010
alicantecoli
  • 22219 Answers
SOURCE: need timing marks for a
Why the problems timing a zetec engine ,its so simple to do and throw the haynes manual in the bin ,wouldnt be to bad if it was written by a mechanic --- anyway these engine have a conical taper on the crank pulley so before you start remove the rocker cover and turn engine over by hand so the slots on the back of the camshaft ar at the bottom and in line with the head ,use a piece of metal straight edge to hold it all in place ,making sure no1 cylinder has the valves closed ,now remove the cam belt tensioner and remove the belt from cam gears ,now slacken the camshaft retaining caps so the cams are loose and all the valves are closed on all the cylinders ,Easy piece this and thats to remove the the lower pulley and to do this you put the socket on the middle nut and nice long bar and wedge it into the suspension somehow ,now crank the engine with the starter motor and this will slacken the pulley bolt ,remove the pulley and change the belt leaving it hanging ,now remove the metal plate on the bottom of the bellhousing and wedge it with a thick heavy screwdriver and get assistant to hold it in place ,now tighten the bottom pulley bolt to a minimum of 120 lbs using a couple of long extension bars and place a jack under the bar at the end to take the strain now with a nice big snap on tommy bay torque this bottom pulley bolt up and put a bar on the end for extra leverage if you not of the physical atire .Right next this toi remove a plug on no1 cylinder and find TDc with a nice long screwdriver ,now turn engine anticlockwise by the bottom pulley by about 30? so no pistons can hit the valves then tighten the cam caps down and make sure you then get the locating bar back into position to hold the cams in place ,bring the piston back up to TDC turning it clockwise and fit the belt .Job nearly done ,turn engine over 360? by hand to ensure the valves clear and then fit the covers back on and away you go
Posted on Sep 27, 2011
emissionwiz
  • 76673 Answers
SOURCE: how to find and set timing marks for 2003 ford focus 2.0 16 valve with dual overhead cams ztech engine
I do not have a diagram but i do have a site with very detailed instruction on how to set the whole thing up correctly, just click HERE
Posted on Feb 10, 2012
How do I set timing in a 2003 ford focus 2.0 engine that has timing marks ?
Remove all the spark plugs and locate the number 1 cylinder. Place finger over spark plug hole and crank engine till it is putting air pressure on finger (this indicates valves are closed and engine) is compressing) insert wooden dowel in plug hole now and crank it by hand to watch for dowel to reach top before it starts back down, and adjust for highest point. You now have #1 at TDC. check cam lobes to make sure the valves are closed and adjust accordingly. Look for video on youtube.
Jul 16, 2017 | Ford Cars & Trucks
Spark plug gap for 2.0 dual overhead cam zetec motor
Certain spark plugs you don't adjust the gap. Spark plug manufacturers may have different gap recommendations. If you want it in inches, try .051 or 1.3mm
May 09, 2016 | 2003 Ford Focus
How to find and set timing marks for 2003 ford focus 2.0 16 valve with dual overhead cams ztech engine
Feb 10, 2012 | 2003 Ford Focus
Timing belt broken.dual overhead cam.don't know how to re-time engine.where do the timing marks line up?
There are no timing marks. Special tools are required to lock the cams and crankshaft in place while the belt is reinstalled.
Jan 08, 2011 | 2000 Ford Focus
Timing marks for 2000 ford focus? can you time the engine with out the special tool? its a dual overhead cam
Mar 18, 2010 | 2000 Ford Focus
Timing belt slipped on 2003 1.6 focus need the timing marks
there are no timing marks as such on the focus mate you have to lock the cams with a setting bar (to do this you need to remove the rocker cover and lock the cams with a locking bar)
the crank is locked up by removing a plug behind the oil pump on the back of the engine (the crank needs to be at top dead center on number 1 cylinder and this can be done by removing number 1 spark plug and using a long piece of welding wire or screwdriver, place in to the cylinder and turn over until the piston is at the top)
with the cams locked and the crank locked your engine will be timed up
please let me know if this has been of any help
cheers
big mike :)
Dec 29, 2009 | 2003 Ford Focus
Cannt find tims marks on 2000 ford focus twin cam
there are no marks on the cams line the crank up you should see marks on it and on the cams take a flat piece of steel like a flat file and put it on the end of the cam shafts the side near near the drivers side ounce you take a look youll see what i mean this should help you out
May 10, 2009 | 2000 Ford Focus
Timming belt replacement Ford 2001 dual cam
You have to leave all of the slack at the tensioner. Get the timing marks lined up on both of the cams and the crank. With the slack left at the tensioner, release the tensioner. It is okay if the marks move a little after this. Manually turn the engine crankshaft twice and then MAKE SURE THE MARKS LINE UP! If they do after two revolutions of the engine, you are good to go. This applies wether or not you are at DTC or not! Remember that!
Please remember to rate this solution.
Feb 19, 2009 | 2001 Ford Focus
Setting the timing
hope this helps- sounds like someone replaced your timing belt and when they replaced it, they were off by one a tooth or peg on the belt- buy a Haynes manual from Advance Auto parts or go to Advance Auto Parts and look for an OPENED 2003 Ford Focus Haynes. Read the part about installation of timing belts. You DO NOT have to remove the timing belt, just make certain it is correctly lined up with the proper marks. If you are a decent mechanic, you can do this yourself. Unlike cars in the 70's you cannot adjust the timing on today's Vehicles
Dec 14, 2008 | 2003 Ford Focus
2000 ford focus twin cam timing
please helpme i need timing marks for ford focus 2000 16 valvs
Sep 11, 2008 | 2000 Ford Focus
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
