Question about Ovens
My oven is loosing temperature
I have a problem with a Baxter oven Model 1 , M800 serial number 34606, nobody can fix it ..it reaches the temperature of 150 degrees and it turns off . At first it used to reach 300 degrees and now its 150 and now it will not even start ...please give me some help or if you know someone in Milwaukee please e mail leaderinjustice@luckymail.com
  • Andrew Armstrong Feb 10, 2012
    To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
    Problem Solver:
  • 8 Answers
Posted on Feb 10, 2012
2 Suggested Answers
SOURCE: 1985 Baxter 30 tray- Oven is set at 496F, oven
Replace high limit, check if the vents are dirty (bottom right and left circlular holes covered in "chicken wire" they could clogged , they are the air intake for the burner , also clean back of the green mixing valves
Posted on Nov 24, 2010
I have a Baxter ov310e oven a customer asked me to check on. Of course while there had no issues at all. She said when they were using it earlier in the day the temp diplay started flashing. It was near...
SAFETY ALARM (STANDARD FEATURE, NO PARAMETER SETUP REQUIRED)If the temperature at the probe is in range of 570 to 600°F for 10 seconds, the unit will do the following:1. Shut off all features.2. Sound an alarm.3. Flash the OVEN TEMP display (actual temperature is displayed).4. Display the letters 'SHdn' in the BAKE TIMER display.Disconnect the electrical power to the oven and follow lockout / tagout procedures.There may be multiple circuits. Be sure all circuits are disconnected.
Troubleshooting - Baxter OV310E Operation Manual [Page 29] https://www.manualslib.com/manual/1248539/Baxter-Ov310e.html?_e_pi_=7%2CPAGE_ID10%2C4341941345 -- shared by UC Mini
Jan 19, 2018 | Baxter Ovens
Creda Double Gas Oven. Model Europa Gas.48132.Serial No: 83 1 00087
I would contact the manufacturer and ask for the repair manual, it does not appear to be available online. Here is a link for the contact form. Hope this helps.
Jul 18, 2008 | Ovens
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
Oven
Tom:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 08, 2018 | Whirlpool Ovens
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
Water coming out oven no steam and it will not get to tempeture
If your oven isn't reaching temperature you will not get steam. Turn the oven on and verify that the oven is calling for heat by looking in the temperature window next to the arrow that says "heat" or "on," if the set temperature is 5 degrees higher than the actual temperature there should be a small red dot next to the arrow. Then observe the burner, does the exhaust fan come on, can you see the ignitor glowing, does the burner light, does it stay lit or go out after 4 seconds? You could have a dirty flame sensor, the small rod with a wire attached to it at the top of the burner, remove the flame sensor and clean it with a cloth, wire brush, or emory cloth.
Jan 02, 2011 | Baxter OV300E Stainless Steel Electric...
Oven, model number 3510PRW does not reach the temperature dialed. To get to 300 degrees I have to put it on 500 degrees. Thank you for your help!
Either 2 thing can go wrong
1. you temp sense probe is failing
2. you temp offset on your dial got loose, or your knob is messed up
Dec 18, 2010 | Magic Chef Ovens
Burners will not stay on until set temperature is reached they shut off and on eratically....please help...
Have you tried cleaning your flame sensor? The little metal rod at the bottom of the burner can be removed and the metal rod that sits in the flame should be cleaned with a wire brush or emory cloth (fine sandpaper).
Sep 30, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Serial Number location
EITHER TOP LEFT CORNER OF OVEN< or UNDER PANAL take off the one screw panel opens right upo like door, Right there!!
Jul 12, 2010 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
109 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
