There is a small plastic coupling between the motor and differential. It is very poorly made. My local service would not open the unit and wanted to sell me a new drive unit or a new scooter. The piece might be worth a nickel. I took a couple of pieces of metal and shaped them into the half moon required to fill spaces to make a permanent connection.
Check that you are not in freewheel.
SOURCE: tire pressure for the The
This scooter may have air free tires not requiring any inflation. This type of tire has foam in the tire and is maintenance free. Look for a air inflation nozzle coming out of the tire. If you don't see one the tire is air free. If you do have a nozzle, then you can add air up to the maximum inflation pressure written on the side of the tire. Hope this helps.
SOURCE: Need owners manual for A ctm hs 740 mobility
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
Hi Scott. do you still have an issue with this?
