Question about Caterpillar Backhoe Tractor
Cat 420d wont shut off - Caterpillar Backhoe Tractor
Cat 420D won't crank over to start , lights all work , battery seems fine
There would be a wire from the ignition switch to the starter solenoid. When the solenoid is energized, it connects battery power from the big cable to the starter motor. When the switch is turned to start, this solenoid wire is hot- has voltage on it. Pull off the wire and check, or just check that the wire has voltage with the key switch held in start. If it is not hot, you have to work your way back to the switch to see where the power is lost. Also test that the switch has power to it from the battery. Eventually you may need a wiring diagram if not able to locate the problem easily.
Aug 08, 2017 | Cars & Trucks
After heating up the engine, when you shut it off i wont start anymore, what is the defect?
Sometimes plugged cats can severely overheat expanding the catalyst material and blocking normal aspiration. if it starts ok when cool, check cat temps when running with infrared non contact thermometer. bad cats will often display temps in excess of 500 degrees. cats are built into manifolds on the six cylinders, one front one rear. sometimes heat shields prevent a good measurement.
Mar 29, 2016 | 2004 Hyundai Santa Fe
Why does front end clunks when my 420d backhoe is in 4 wheel drive
your drive shaft is going bad check the joints on shaft for wear or looseness
Feb 18, 2015 | Cars & Trucks
My cat 420d is very delayed on shutting off after turning the key off
check to see if it is turbo and if so may have a delay setting to allow the turbo to cool down. ( should run for about 1 minute)
Dec 21, 2014 | Cars & Trucks
Caterpilla backhoe 420D hour meter not working
Go to this link, search the forums for help with 420 cat hour meter. It is probably a simple fix even if you have to replace the unit. Join the forum for free, and ask your question in the tractor-backhoe forum. THANK any one who offers assistance and let the forum know what you finally did to fix the problem so WE CAN ALL benefit from your experience! There are many wise operators,owners, and mechanics on this site.
Mar 28, 2014 | Caterpillar Backhoe Tractor
CAT 420D IT - lack of power- changed two fuel filters, one by injector pump and other between left front tire and fuel tank. Air filters cleaned, tractor serviced, Then used air to blow thru lines back...
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to Factory Installed Systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Nov 02, 2012 | Cars & Trucks
No starter engagment on cat 420d bachoe no power
From what I have discovered with my own Cat 426 it is likely the forward reverse selector. It has electronics and contacts that will NOT allow the starter to receive any power if the contacts are open as there are safety interlocks that will not allow the machine to start.
May 18, 2010 | Caterpillar Backhoe Tractor
Filters have been clogged with wet cat litter and now the vac will turn on but shuts off and wont cont to vaccume. can we clean/rinse the filter out. filter light has come on and then turns off once the...
Using a vacuum cleaner for wet cat litter??? Not a good idea at the best of times! The machine's cutting out because it's overheating. You don't tell us the make or model of your machine - some filters are washable, many are not. Your user manual should tell you. As a general rule, cloth- or sponge-type filters are probably washable, paper ones are not. If you do wash the filter, give it at least 24 hours in a warm place to dry thoroughly before re-using.
Jan 24, 2010 | Vacuums
My ford contour wont start up
98 FORD CONTOUR CAR DIED HAD FUEL PUMP REPLACED. TOLD IT NEEDED CAT AS WELL DONE ALSO. CAR STILL WONT START AND STAY RUNNING PROPERLY. WHEN IT DOES RUN ITS IN SHORT SPIRTS AND STRONG FUEL AND SMOKE COMES OUT OF TAILPIPE?
May 24, 2009 | 1999 Ford Contour
Caterpillar Backhoe Tractor Logo
121 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
