Need codes for the Yamaha Rav334 universal remote
SOURCE: remote code
HOPE THIS HELPS U ...
http://www.fixya.com/support/p149430-yamaha_htr_5830_5_1_channels_receiver/manual-20151/page-10
SOURCE: Codes for Yamaha HTR-5240
just go here and download the manual...
http://www.usersmanualguide.com/yamaha_audio/av_receivers/htr-5240
it has all the codes listed
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
SOURCE: what is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
