Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Does not make ice
Was not making ice and dripping water into the ice container. I changed the water filter to improve the water flow.. Ice would start to be made after the frig was shut off for 8 hrs., but it would soon stop making ice again. Water was again dripping into the ice bin. TY Walt
    Scholar:
  • 121 Answers
Hi! Walt42
Sound like the electrical fill valve to the ice maker is not closing all the way. It may have a piece of something in the valve. You should be able to remove the valve and try blowing through the valve. If in dought remove the outlet line from the valve and see if any water runs out.
InMrFixIt
Posted on Dec 16, 2008
Water no longer flows and therefore no ice. I've changed the filter. No improvement
Check to see if old ice remains inside the ice slots. If not then fill with tap water and allow to freeze. If after the water freezes and cubes drop into the ice bin you will need to replace the dual water control valve. If ice maker does nothing then the ice maker will need replaced. What is the model number?
Appliance 911 Sea Breeze
Oct 04, 2015 | Refrigerators
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
Change water filter indicator came on so i changed the water filter now the refrigerator won't make any ice, checked the on off button in the ice making unit which is on, what the problem?
This unit has water dispenser and ice maker? If yes, you must get all the air out of your water line, how to do this is keep fill water glasses until you get a good flow of water and no more air, also the water may drip some what so. until all the air is pushed out of the line your ice maker can not make any ice, please let me know what you find. Thanks Rick...
Jul 26, 2011 | Refrigerators
Water takes a couple of seconds to come out and not making ice
Check the water supply lines feeding the refrigerator for crimps or hard turns and even if someone put a self taping tap valve as a shut off. They tend to restrict flow. If you find a tap valve remove it and have Tee placed there with a shutoff. It also does not hurt to pre-filter water going to the refrigerator. Lowes or Home Depot have some good in line filters that you just plug feed in one end and supply to fridge on other end. If it had air in the water you would have dripping all the time and noise of air rushing out once the dispenser valve is pressed. I am checking if your model has a filter somewhere. Have someone turn water off and disconnect the water feed from refrigerator and place lin in a pan or container and then have the turn it back on so you can visually see the flow. Disconnect power so if things get out of control water does not cover the electrical parts of the refrigerator. Let me know, Thanks Sea Breeze
May 16, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not filling with water or making ice- GE pfss6pkwss
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 01, 2009 | Refrigerators
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
The ice is working fine. However, the water will not flow. Water was working fine. I was out of town for about 4 weeks and the filter light was on when I returned. I changed the filter and now water...
Remove the drawer containing the Ice cubes , and blow a hair on the pipe where the water come in. If it wasn't used for 4 weeks perhaps the nozzle in the inlet pipe froze. Then put the empty drawer back in so the ice maker thinks it needs to make ice and see if it will work
Hope this helps
Loringh
Nov 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
80 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
