Question about Video Game Consoles & Games
MY PS3 IGOT THE GAMES OUT BUT NOW IM HAVING TROUBLE PUTTING THE DISC DRIVE BACK TOGETHER PROPERLY
  • Nathan Ayers
    Nathan Ayers May 11, 2010
    Where are you stuck at? you mean you cant do it at all and you just have a pile of parts... or you are having a problem with a certain step?
  • 98 Answers
Try to re-trace your steps and figure out what looks right to you and as long as you put it together and it works dont worry.
Posted on Nov 20, 2008
My ps3 slim blue ray drive will not accept discs. it wasnt reading them so i took the drive out and tried cleaning it but forgot my game was still in it so i removed it manually. when i put it all back...
OK, all the answers I see here don't look like they was reading your problem and what you did. You most likely should take it back apart and put the disc back in it that way. Since you took the disc out the PS3 thinks there isn't and is a disc inside. When you press the eject button it's not going to reset the disc arms inside because there isn't a disc in there and that white thing is there to keep a disc from going in with a disc inside even though there isn't one. You should go ahead and order another laser and when you take it back apart change the laser also slim PS3 are more common on the laser going bad I've changed alot of them. But when you change that make sure you either put a disc back in or move the arms and slides to where it's ready to accept a disc when it's put back together.
Nov 01, 2017 | Sony PlayStation 3 Slim Black Console
After having trouble with disk ejecting, that was resolved im now having trouble feeding the disk
Ok the ps3 cd drive top and bottom are synchronize together to work together. You need to take the cd drive apart again hook it up to the ps3 without the top lid of the cd drive on and press eject. The simply put the cd drive lid on directly from the top not to one side but directly down ontop of the bottom part of the cd drive. Then down put any screws in start missing with the disc see if it goes in and out. If you still hear odd noises you can do it this way 3-4 times until you have the top lid aligned with the bottom part. Or another way a little more difficult is get the disc drive to have a disc in it and take the cd drive apart. Then with the top part in your hand slide a disc in the top part and hold the disc through the middle hole with your finger and simple place it back on the bottom part of the drive. Its an easy fix but a little hard to explain if you still need help let me know. Also it could just be your gears needing greasing. You can use a qtip and any thick greasy solution. I've used baby lotion **** paste vasoline all of those at diffrent times when I couldnt find anyhing else and that will fix it.
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
The system will not properly turn on and any games will not play properly
brollyss5us
If you are having trouble with your PS3 booting up properly this is a sign that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 10, 2010 | Sony Playstation 3 (PS3) Console
The game will play ok when you get kill the game freezes nothing happens you eject the game, put the disc back in and nothing happens could you suggest what it is. i tried different games and it is the...
paul5048
If you are having trouble with your games freezing it is possible that you have corrupted data on the PS3 hard drive. The link below will take you through resetting the drive.
If you still have trouble it is possible that you are having trouble with the PS3 system its self.
Issken
May 31, 2010 | Sony Playstation 3 (PS3) Console
Got a game stuck in ps3 took it apart got game out put it together again,now when i turn it on it shows green then turns off
you might have damaged your disc drive. if there was a cord connecting the top of the ps3 and the disc drive and it got disconnected try reconnecting it by putting it on the top ps3 cover and back into the tray. takes alot of work if you don't want to send it back in.
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
CANNOT REMOVE DISC GAME STUCK IN PLAYER UNABLE TO REMOVE DISC FROM PLAYER
open up your ps3 you tray might have broke or the game is stuck up to where it wont let you open it.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Games will not load,I have tried movies,and games,everything else seems to be working fine,just cant play movies or games..
Ok, if you are having problems with loading games/movies that are disc based and not ones that are in the HDD (Hard Drive) or on a usb drive (This means digital movies and games), chances are your PS3's Blue Ray drive is damaged and you will need to get a replacement. If you can't play anything even if it's Digital/HDD based or Disc based, you may have to send it in for repairs, or get a Replacement PS3.
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont play ANY disc
if its not playing any bluray disc/games then its major trouble..you will have to contact sony for a replacement if its in the warranty period..had the same problem and customer care in India sucks..anyway hope its not something serious...are u getting any error code?
Oct 29, 2008 | Sony Playstation 3 (PS3) Console
Ive done most all i can do...
if you bought this new ti shouldn't really be doing this, I would take it back, but however, if it isn't playing anything at all and it isn't new try restoring it to factory default.
To bring the PS3 to factory settings, you need to use the reset to facorty deafults in the system settings menu, not the restore system under backupdefaults.
you will lose all data because it will fomat the hard drive. I think this might be your best option.
Good luck I hope this works
Oct 25, 2008 | Video Game Consoles & Games
Draive wont take discs
Hi Spooks,
When you put the Disc drive back together, the mechanism probably did not go togther properly. You have to put it together with a disc in the drive. It is very hard to get the disc player to go back together properly I know. I needed three hands to do it. I done one. It took me several tries, but I finally got it. Another thing, since you have already disassembled your PS3 and need to do it again, go to Radio shack and get some Thermal heat transfer compound, Replace the compound between the heat sinks and processors. The original compound dries up after about a year and will kill your PS3 completely if you do not do this. Good luck,I know its not going to be easy.
Nov 05, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
