Question about Kenmore Dryers
How do you fix a dryer drum that has too much lateral movement?
It makes a lot of noise, but the motor turns the drum the drum appears to move too much from side to side
  • 16 Answers
SOURCE: Miele T 1515 electric dryer
Blower fan has fluff on stuck to it. It may even be disstorted. If you are really unlucky then it's done the blower fan motor bearings as well.
Posted on Feb 08, 2008
  • 319 Answers
SOURCE: Bosch nexxt model gas dryer - screaching noise coming from Bearing shield
call tech support
Posted on Mar 11, 2008
IFIXALL
  • 868 Answers
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
SOURCE: Have a "finshing" noise even when drum stops a turn
I had a similar problem and found a screw had backed out on one of the turning paddles inside the drum but the screw was on the under side , and could reach it through the access door , just had to turn the drum by hand till the screw was in sight.
just turn the drum inside by the paddles and shake them to make sure they are tight , thats how i found my problem and noise
good luck hope this helps , wayne t
Posted on Jul 14, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
It is makeing a lot of noise
Hello. You didn't provide a brand/model number or the type of noise the unit is making. If the dryer is making a screeching noise, it's probably the idler pulley(spring-loaded tensioner pulley that keeps the drum belt tight so the electric motor can turn the drum properly) being worn out or binding up due to lint build-up in the dryer. However, if the dryer is "thumping" loudly, most likely it's a worn out support roller either on the front or rear bulkhead. They're made of hard rubber and can become malformed due to wear/age causing a rough movement of the drum as it spins.
Aug 18, 2015 | Dryers
How do I fix my whirlpool cabrio dryer model wed6200swi so that it stps the noisy squealing sound when it runs?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Mar 04, 2015 | Whirlpool Dryers
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
How do I fix a squeaky dryer
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 08, 2014 | Dryers
How do I fix squealing and scraping noise in my Kenmore gas dryer 110.74812200?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 21, 2014 | Dryers
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
Aug 14, 2014 | Kenmore 84052 Dryer
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
My Neptune dryer makes a lot of noise while running sounds like bearings rattling what do in to do to fix?
the problems could be many. agreed its something that moves from your description.
moving parts are
motor, belt, drum, drum rollers (or glides but they dont move) could make noise if so equipped), fan in housing going to heater.
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Maytag Dryers
Our Hotpoint tumble dryer has had a new drum and belt put in 4 days later it is making a horrible grinding noise.
Its possible that the noise is comming from the movement of the drum,the motion of the motor,belt pully or drive spindle.It will be good to reassemble and manually check the moving parts for the noise.
Sep 29, 2010 | Hotpoint Dryers
How do you determine if the motor is bad on gew9200l duet dryer
Check the amperage withe the heat off is one way. Another is to unplug dryer and feel the moter shaft for shaft play or sloppy movement. Amprege to the motor can also be checked. Sometimes it's not the motor but where the drum attaches in rear and the rollers the drum.
below is a link to a PDF of your dryer parts
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180467.pdf
Mar 28, 2009 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
20 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
