Question about Brother HL 1440 Laser Printer
Brother hl-1440 laser printer
A four inch wide horizontal solid black line gos staight down the entire page. If your facing the paper it is mtowards the right of the paper
  • Brother Master
  • 5,568 Answers
Did you mean 'vertical' (from top to bottom) line rather than horizontal? If it goes 'straight down,' it has to be. I think so, otherwise the added info that it is closer to the right wouldn't make sense.
This problem is normally due to contaminents on the surface of the drum itself although can also occur if a wire that discharges the excess toner from blank areas could be dirty.
Changing the drum cartridge will correct either of those problems since they are contained in the drum cartridge. If you are using 'recharged' cartridges and it only has a few copies on it, most companies will exchange it for you.
Posted on Oct 23, 2008
My Brother HL-2140 Laser Printer prints horizontal lines (about 1/8-inch long) at right hand edge of paper. They are spaced at about 2.5 inches apart down the page. Help!
It is most likely that your Laser Unit is failing. It could also be dirt on the electrodes of the drum unit and machine body or the ground terminal on the paper tray is bent. It is best that you visit you local Brother Authorized Service Center for additional help.
Thank you for using FixYa! - Don't forget to rate our service!
Feb 07, 2010 | Brother HL 2140 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
A solid black 1/4" line the length of the page about 1" in on lef
the first thing to check on the brother is the corona wire strip, its the blue slider on the drum cartridge, it should be locked to the side if it is not it will cause such a line
Apr 02, 2009 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser printer-horizontal black streaks
check your drum may the corona ware is broken . change the drum.
Feb 27, 2009 | Brother HL 1440 Laser Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Toner cartige
clean the roller. the toner you have installed may be defective.
did you have the same black squares before you change the toner???
Oct 29, 2008 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
282 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
