Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
How do i fix error code 6202 on kodak esp c315 printer
  • 19 Answers
SOURCE: New printer Kodak ESP 5
ok i guess i need more information regarding the error code you are recieveing .... exactly what are you trying to do that prompts this error code to pop up ?
Posted on Aug 19, 2008
  • 20 Answers
SOURCE: Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Posted on Apr 01, 2009
  • 60 Answers
SOURCE: kodak esp 7 paper jam
you will get a new only if the printer is within 30 days from the date of purchase so it is ok to have refurbished printer,,,,,,,just give them a headache when you have problem with this..........
Posted on Jul 08, 2009
shockwave727
  • 262 Answers
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Posted on Nov 08, 2009
SOURCE: printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Posted on Jan 16, 2010
Printer error code 6202
Check that you have installed the correct (and full) cartridges. If you are using refilled or compatible cartridges, you may find they need a replacement RF chip.
Sep 08, 2014 | Kodak Esp 2150se Wireless Office...
Kodak ESP C315 Error code 3513 missing print head
Kodak esp c315 .i have the kodak esp c315 and keep getting the printhead loose missing or not installed correctl
Apr 14, 2014 | Office Equipment & Supplies
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
To resolve this error:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
On a 7250 have error code 6202, having..
When the printer is ready (no error message), upgrade the firmware.
If the error continues and you cannot upgrade the firmware, contact us.
Feb 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Mi impresora kodak Esp 5 Muestra en su pantalla " error de la impresora" Código de errro 6202" ¿Qué hago?
To quote Shockwave727:
to solve this
-Unplug power cable
Sep 28, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
My Kodak ESP 7250 has been working fine but suddenly came up with Error code 6202.
Possible ink cartidge level being less.
Open the printer properties to check on the levels. If not remove the printer and connect once again affer shutting down PC.
If this wont work then remove printer, uninstall and reinstall, then connect to check if the printer is detected and installed.
If not drives are jammed/ the main board has errors..
Sep 12, 2010 | Office Equipment & Supplies
to solve this
-Unplug power cable
Nov 07, 2009 | Kodak ESP 5 Printer
Setting up a new Kodak All In One printer and keep getting error code 6202
Hi!
This is a error message of the scanner.
1. Turn printer on.
2. Unplug ac adapter.
3. wait 1 minute.
4. Plug ac adapter in printer.
5. wait until the printer is ready.
when the error still occurs, the printer is definetly defect.
Jun 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 1-2036 on Kodak ESP3 printer
Perhaps this will help, universal error codes for the Kodak 5100 thru ESP 9 inkjet printers:
RME: Kodak
STATUS_OK_ALL = 0,
STATUS_OK_MANUAL_DUPLEX_STARTED = 97,
STATUS_OK_MEDIA_DETECT_STARTED,
STATUS_OK_FORM_FEED_STARTED,
* Informational (0100-0999):
* Busy (1000-1999):
STATUS_BUSY_SYSTEM_BUSY = 1999,
* Warning (2000-2999):
STATUS_WARNING_IMAGE_TOO_LONG = 2998,
STATUS_WARNING_IMAGE_TOO_WIDE,
* Asynchronous Ok (3000-3099):
STATUS_OK_MANUAL_DUPLEX_COMPLETE = 3000,
STATUS_OK_PAGE_EJECTED,
* Asynchronous Warning (3100-3199):
STATUS_WARNING_BLACK_INK_LOW = 3101,
STATUS_WARNING_COLOR_INK_LOW = 3102,
STATUS_INK_TANK_INVALID_MANUFACTURER_COLOR = 3103,
STATUS_INK_TANK_INVALID_MANUFACTURER_BLACK = 3104,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_COLOR = 3105,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_BLACK = 3106,
STATUS_MEDIA_VERSION_EXCEEDS_FW_VERSION = 3107,
STATUS_INK_OVERFLOW_EXCEEDS_CAPACITY = 3108, // Will be deprecated
STATUS_WARNING_BLACK_AND_COLOR_INK_LOW = 3109,
STATUS_WARNING_PROOF_SHEET_WRONG_MEDIA_SIZE = 3110,
STATUS_WARNING_PROOF_SHEET_WRONG_SESSION_NUMBER = 3111,
STATUS_WARNING_PROOF_SHEET_NO_IMAGES_SELECTED = 3112,
STATUS_WARNING_PROOF_SHEET_READ_ERROR = 3113,
STATUS_WARNING_MORE_THAN_1000_IMAGES = 3114,
STATUS_WARNING_INVALID_DPOF_FILE = 3115,
STATUS_WARNING_NO_IMAGES_FOUND = 3116,
STATUS_WARNING_SCAN_TO_OPERATION_FAILED = 3117,
STATUS_WARNING_BLUETOOTH_CONNECTION_DROPPED = 3118,
STATUS_WARNING_UNSUPPORTED_USB_DEVICES = 3120,
STATUS_WARNING_OVERCURRENT_USB_DEVICE = 3121,
* Asynchronous and Synchronous Error (3200-3499):
* Job Recoverable. No User Interaction.
// STATUS_PRINTER_BUSY = 3201, // not used. duplicated number
STATUS_INK_TANK_REPLACEMENT_IN_PROGRESS = 3207,
STATUS_PRINTHEAD_UNCAPPED_TIMEOUT = 3208,
* Asynchronous and Synchronous Error (3500-3599):
* Job Recoverable. User Interaction Required
STATUS_ERROR_UNIT_OPENED_WHEN_IDLE = 3501,
STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY = 3502,
STATUS_ERROR_PHOTO_PAPER_TRAY_EMPTY = 3503,
STATUS_ERROR_PAPER_JAM_DURING_PICK = 3504,
STATUS_ERROR_NON_PLAIN_DETECTED_DUPLEX = 3505,
STATUS_ERROR_MEDIA_SIZE_MISMATCH = 3506,
STATUS_ERROR_INK_OUT_BLACK = 3507,
STATUS_ERROR_INK_OUT_COLOR = 3508,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_COLOR = 3509,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_BLACK = 3510,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_COLOR = 3511,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK = 3512,
STATUS_ERROR_PRINTHEAD_NOT_INSTALLED = 3513,
STATUS_ERROR_BACK_COVER_REMOVED_WHEN_IDLE = 3514,
STATUS_ERROR_CARRIER_STALL_DURING_PICK = 3515,
STATUS_ERROR_MEDIA_LOADED_UPSIDE_DOWN = 3516,
STATUS_ERROR_INK_OUT_BLACK_AND_COLOR = 3517,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK_AND_COLOR = 3518,
STATUS_ERROR_PHOTO_TRAY_ENGAGED = 3519,
STATUS_ERROR_FAIL_TO_DETECT_PAPER_EDGE = 3520,
STATUS_ERROR_VOLTAGE_TO_PRINTHEAD_NOT_CALIBRATED = 3521, // Should only be used at the factory
* Scanner (6000-6299):
SCANNER_ERROR_ADF_PAPER_OUT = 6101,
SCANNER_ERROR_ADF_PAPER_JAM = 6102,
SCANNER_ERROR_MOTOR_LOCK = 6201,
SCANNER_ERROR_MOTOR_MOVE_FAILED = 6202,
SCANNER_ERROR_HOME_NOT_DETECTED = 6203,
SCANNER_ERROR_CALIBRATE_FAILED = 6204,
SCANNER_ERROR_ADF_SENSOR_FAILURE = 6205,
/* Internal used errors. to be removed */
STATUS_ERROR_PAPER_JAM = 3201,
STATUS_ERROR_CARRIER_STALL = 3202,
May 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
204 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
